Question about Whirlpool LSR6232J Top Load Washer
Can't get the end caps on the console removed
  • 304 Answers
Behind each end cap (back of washer) you will find a screw hidden beneath a plastic tab. Place a Phillips head screwdriver against the tab and onto the screw. Unscrew it and then pull the control panel forward toward the front of the washer. Lift the head by the end caps and rotate it upward. It will stay attached to the back panel and expose all the parts inside the control area.
Posted on Oct 05, 2009
Water does not drain, doesnot spin
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 16, 2009 | Kenmore Washing Machines
Tub fills then does nonthing no noise of anykind
Aug 20, 2009 | Kenmore Washing Machines
How do i remove the console of my kenmore washer
Jul 09, 2009 | Kenmore Washing Machines
Kenmore 70 series stuck in rinse cycle, won't drain
Jul 05, 2009 | Kenmore Washing Machines
Wont spin still has water in it
Jun 30, 2009 | Kenmore Washing Machines
Dryer wont come on when button is pushed
Jun 26, 2009 | Kenmore Washing Machines
Not spining
May 04, 2009 | Washing Machines
SEQUENCIA DEL TIMER LAVADORA G.E
May 03, 2009 | Washing Machines
Remove console
The console can be removed in a few different ways depending on your model number:
1. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
2. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Some consoles have screws in the back that require removing before the entire panel will slide forward, then lift back.
You should post back with your COMPLETE model number (located on a nameplate under along the wash tub opening under the lid) if you ruin into any difficulties. I hope this helps you.
PS Is there a reason why you are removing the console?
Aug 07, 2008 | Kenmore 24032\24036 Top Load Washer
How do I remove the cabinet on a Kenmore Model 11022882101 top loading washer?
You need to remove 2 screws in console. They might be in back, on ends or in front ends. If you can't see any, they are under the console end caps. To remove end caps, pry off by pulling caps towards outside from center part of cap. Pry toward you and towards outside. Then remove 2 screws and flip console up and back. Unplug connector to washer cabinet. Remove 2 gold colored clips by inserting straight screwdriver in them and prying back. Make not of their position first. Now tilt cabinet toward you and slide forward and off base.
To replace, tilt cabinet and slide under frame in front. Now lower cabinet on to frame, making sure cabinet is on frame on sides. Re-install clips by placing them in position and pushing down with palm of hand. Plug in connector, lower console and install screws.
Nov 21, 2007 | Washing Machines
Whirlpool LSR6232J Top Load Washer Logo
Dan Webster
Dan Webster
Sal De
