Question about ION Audio Vinyl Recording Turntable
Ion USB turntable is not recording both stereo tracks.
  • 28 Answers
CHECK TO SEE IF YOU ARE GETTING SIGNAL ON BOTH CHANNELS OUT OF THE TURNTABLE IF ONLY ONE SIDE FAULT IS AT THE CARTRIDGE CHECK CONNECTIONS AT REAR OF THE HEAD SHOULD HAVE 4 IN PLACE
Posted on Nov 04, 2009
Why do I not get full stereo spectrum on Ion Profile Pro turntable when connected to Dell computer?
This toy player, can be used with a USB cable, but also with tulip plugs. When you have an amplifier, you at least can test if the sound coming from the element is in stereo. If that sounds good, you know there could be something wrong in the A/D convertor in the record player, or still your computer can't handle the digital signal coming from the USB connection.
Here I found a Video, where they use the analog output and connect it to a pair of computer speakers direct.
Ion Profile Pro USB Turntable Review
Jan 22, 2015 | Audio Players & Recorders
Hi there,I've contected my ion profile flash using a usb but it keeps saying "No Dev"
This is the USB flash turntable it dose not connect to a PC
you connect it to your stereo or record direct to USB or SD card
i am also getting this No Dev on the screen
anyone any ideas as non of the buttons funtion
Jul 30, 2011 | Audio Players & Recorders
Not all of the sound/music is being transferred from the LP.Hard to explain, but its when the LP has sound coming out of each speaker independent of one another, only one side is coming out on the recorded...
I know this is an old post, an I dont' have a solution yet, but t seems the same problem as on my Ion USB recorder - One of the input channels is not working. Like you, I found one of my music tracks not plying right - there was only the instrumental and no vocal. When I experimented, and changed round the jacks on the cable coming from the turntable (red and white plugs), I then got only vocals and no instrumental. Obviously one of the input sockets on the USB recorder is no longer working (I already checked the turntable and cable itself by playing back he same track with both stereo channels through my amplifier). You can either get the item replaced if its still under guarantee, or fix it yourself, if you have the necessary skills, neither of which apply to me.
Apr 22, 2011 | ION Audio Vinyl Recording Turntable
I am only getting one channel when recording from Numark Ion Usb turntable, using Audacity software. The software is configured for stereo, but left track is not recording (and no sound from speaker...
Set your Audacity software to STEREO MIX on the main window. Go into EDIT, Preferences and set the recording device to your sound card and the channels to 2 stereo.
Mar 07, 2011 | ION Audio iTTUSB Turntable
ION TTSUSB10 does not record stero
I solved the problem by using www.wiki.audacityteam.org home page under the technology heading and clicking on USB turntables. The mixer had to be changed to 2 channels. (stereo)
Jan 05, 2010 | ION Audio TTUSB10 Turntable
Trying to install a ion iTTUSB on computer but not
READ your quick start booklet. You need to go to control panel, open sound, there are three tabs- choose playback and make sure that the selected speaker is not USB Audio Codec-choose your speakers. In the Record Tab selcect USB Audio Codec.
Dec 15, 2009 | ION Audio iTTUSB Turntable
ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Dec 03, 2009 | ION Audio TTUSB10 Turntable
Recording in mono and not stereo
Thanks for your rapid response. Fortunately I discovered the problem and was able to resolve it. Whether it is just my computer or all computers I wouldn't know. When I switched my computer off, after recording vinyl to my pc, then switched it back on again my pc had reset the default input so I had to reconfigure it again. Since then I have not used it but wonder if I have to reconfigure the recording device everytime that I switch my computer on. I did make the USB Codec microphone my default recording device and applied the setting but the pc seemed to do its own thing.
All the best
Paul Watson
Dec 28, 2008 | ION Audio TTUSB10 Turntable
Recording one channel only
I had the same problem on a turntable and it was the cable, those rca cables are notorious for breaking inside at the plug end. The stylus cartridge not being completely plugged in may cause it too I imagine. I'd bet it's the right rca cable broken inside at the plug end.
Aug 05, 2008 | Gem Sound DJ-2100 Turntable
It doesn't work!
with everything plugged and running go to preferences in FILE and set Recording Device and channels to Audio device USB in Audio I/O.Tick software playthrough.
now set the microphone box to Stereo mix on the home screen(box is left of small scissors) hope this helps.nigel.
Dec 26, 2007 | ION Audio iTTUSB Turntable
ION Audio Vinyl Recording Turntable Logo
248 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Jose Ma DM.
Jose Ma DM.
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
