Question about Maytag PYE2300AY Electric Dryer
How do i get too the belt, motor assm.? - Maytag PYE2300AY Electric Dryer
  • 3 Answers
There is a plate on the lower back side
Posted on Oct 07, 2009
95 labaron, serpentine belt comes off.
One of the pulley's the belt drives is off center. Not knowing what engine you have I would have to say you need to replace the water pump. Check the alternator bolts one may have vibrated out also the powersteering pump and A/C compressor and idler pulley assm.
Apr 13, 2013 | 1995 Chrysler LeBaron
Whirlpool Washer Mdl # LSR8233JQ1 Type 111
Have you tried unplugging it and plugging it back again? Try it without clothes inside, does it spin? Check the lid switch for continuity. Then probably its the motor coupler check if its connected directly to the motor first, you can replace it if you should its worth about $40++. Next check the clutch and transmission, those are the parts where you should go and check. But if its a transmission problem it might cost you around 200 bucks or more so better to buy a new one instead.
Jan 26, 2008 | Washing Machines
Hp printer 1312 fadad print how to fix
Check any refilled cartridges?.. No.Go to main menu select default setting.. check for the quality..No..
Need to clean reflecting mirrors in scanner assembly..Only professionals can perform this activity..
Remove right, left & back doors..
Detach the cable which came from flat bed assembly, remove two screws back side just below of flat bed, gently push flat bed assm back to front, lift & take out the flat bad unit.. remove upper cover, you can observe the scanner assm ( see the snap shot) "Note: to take out scanner assm cartridge & cartridge bank must be present in to the printer to prevent the damage to transfer kit, other wise scanner will fall down on transfer belt" Unlock & remove scanner secure pins(4nos), detach scanner flat cable connected to DC controller, take out scanner assm, open the bonnet of scanner assm, clean surface of the mirrors very very gently with ear buds.Don't disturb any factory settings, once its cleaned refix every thing back.. "Note: scanner flat cable which is connected to DC controller is not that much lengthy, before powering on check once cable connected in properly or not, if any thing goes wrong in this area printer wont power on & it may damages the DC controller or scanner assm .." But I am sure that only professional can perform this activity, if you are not qualified pl don't try it..5_25_2012_8_24_06_pm.jpg
May 25, 2012 | HP LaserJet CM1312 All-In-One Printer
Oiling the laser scanner motor
Remove top & side covers to reach laser scanner assm(see laser scanner assm,fig1) remove cover as specified in fig, remove 'C; clip to un lock ,take out scanner motor, lubricate shaft with good lubricate fix as it is..try..
For further assistance pl get back... pl take care while handling motor to aviod fingure printers on reflector..
Feb 05, 2012 | HP LaserJet 2200 Printer
How do I clean the laser mirrors myself? is there a manual or video that can show me how. i don't have the money to pay to have it done. the cheapest quote i have gotten is way more than i can...
Fist you need confidence.. then only you try it.. no video/manual for this, because of its no suggestible. Read once again & once again understand it then try it..
Open back cover & side covers.. two boards you will found at back side left one is formatter & right one DC controller. remove both DC & formatter, mark the connectors where you removed.
Remove the plate where DC & formatter placed,after that only you will find the scanner assm.
Two screws only protected to scaner assm, mark them where you removed.
Scanner assm: While cleaning the scanner assm must be wear glows..to avoid finger prints.
Remove the scanner assm cover(two screws) & shutter. Observe two motors with four reflecting mirrors, clean the mirrors & engine reflector sides(a squared metal part which was rotates along with the motor) with ear buds
gently. ( ear buds are good cleaning method) while fixing the unit back ensure that seated properly.. fix back every thing & do calibration.. check the print quality, if you failed to fix the scanner unit in properly, you need to do entire things once again.. Good luck..
Sep 27, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Hp laserjet 2420n 52.00 error solution
If you are tec guy.. This is Laser scanner assm faulty.. Check scanner cable connections. Open scanner assm remove cover check motor rotating freely or not if its not free, open rotor lubricate it & fix check for free movement..(before opening the rotor ware glows, don't touch rotary reflector area)
Sep 13, 2011 | Office Equipment & Supplies
HOW DO YOU CHANGE BELTS ON TORO 824 SNOWBLOWER
you have to ssplit the snow blower in half to get to the belts. Its easy but make sure to replace both belts and also check the auger bearing they are known to wear out and the auger belt will not get tight. The bolts are on ether side behind the auger assm
Aug 20, 2009 | Garden
Seat belt problem for ford escort 1995
The cable is plastic and strips out very easy you will need to replace the assm.
Aug 02, 2009 | 1991 Toyota Camry
I have a kirby Tradition. The belt has come of and also the bit you turn to stretch the belt. I have all the bits but no idea how to put it together
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=656063
Generic problem for all Vacuums
I have a Kirby Tradition.
Posted by Pagan1 on Jun 08, 2008
I have a Kirby Tradition. The belt has come of and also the bit you turn to stretch the belt. I have all the bits but no idea how to put it together
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I have never come across the entire belt hook assm has come completely apart, but I have seem other people put the assm back together, but I would bring it to a local Kirby vacuum cleaner dealer in your area and if for some reason they cannot repair the Kirby head and hook assm they can order you a compete head totally repaired, but that would be choice #2 or feel free to contact your local Kirby Vacuum Cleaner Dealer to give you a breakdown on how to put it back together again. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hour’s 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 08, 2008 | Vacuums
The rubber band that turns the roller on the vacuum keeps breaking. I just bought a new rubber band, put it on, and it broke immediately. Can it be fixed?
I see there could be 2 problems – either your revolving brush has hair or thread buildup in the ends of the brushroll of which is causing the belt to break and would need to be cleaned out, or check the bearings on each end – they could be **** as well, or the motor shaft or motor assm is not tuning freely and in that case the motor should be replaced and it is not the belt – one other thing is to make sure the motor is in there securely. Once you get the belt on then roll the pulley and the belt together to make sure the belt is on correctly if the brushroll spins freely.
Apr 18, 2008 | Vacuums
Maytag PYE2300AY Electric Dryer Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
