Question about Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100)
Need the default gateway and name servers for 327W
  • 8,404 Answers
You set these names ... if you dont set the name, no big deal
Posted on Oct 05, 2009
Router password change
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
•All your settings will be lost including network encryption information, MAC Address filtering information, and any SSID information you have entered.
•The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
•You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Dec 27, 2011 | Westell Wirespeed VersaLink...
Tip
Why can't you connect to the Internet?
First check your TCP/IP address - see my earlier tip on checking you are connected to a network. For most recent systems, (not Linux) open a command prompt window (type "cmd" in the RUN window from the start menu) and type ipconfig /all
you should see your network adapter name and IP address, a subnet mask (don't worry) and a default gateway, also a DNS server IP address. If ANY of these are missing, that's your problem, try repairing or resetting the network adapter. WRITE THEM DOWN. You may have more than one adapter, you need to identify which one is used for the Internet connection.
If they are all there, from the SAME window type "ping" followed by the IP address of your default gateway. If this fails, you have no connection to your internet router, find out why!
If this succeeds, type "ping" again, followed by the IP address of your DNS server. If this fails, type "tracert" and then the IP address of your DNS server. The FIRST address that will be reported is your default gateway; followed by your ISP address; if the only address you see is your default gateway, the link to your ISP  is down, give them  a call. If it succeeds, from the same window type "nslookup"
You will see a chevron prompt, type in the name of the site you want to go to, e.g google.com.
You should then see a reply from your DNS server, and an IP address for your required server. If not, then either your DNS server settings are wrong OR the server does not exist. It will be obvious which it is from the reply you receive. If the DNS settings are wrong, you can change them from the Control Panel, Network, Network adapter, Properties, TCP/IP v4 properties menu; try setting DNS server to 8.8.8.8 or 8.8.4.4 and try again.
on Mar 26, 2010 | Computers & Internet
Need to reset password
Dec 04, 2011 | Westell Wirespeed VersaLink...
I need gateway and dns numbers to connect samsung bluray mod# bd-d5700/2a with 327w mod#wis09abgn can you help me
On your computer open up a command prompt (click start, then run, type in cmd press enter)in the command prompt window type in IPConfig /allThe output of this command will give you your default gateway and DNS information for your network
May 29, 2011 | Westell Wirespeed VersaLink...
My grandpa set up our wireless network a few years ago, but bless his heart, he passed away just this year and we forgot our WEP key and we need to reset it or just get ahold of it so the family can access...
Sorry for your loss.
  • Note: Resetting your router to the factory defaults not only changes your gateway user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your gateway to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and network encryption key.
  • All your settings will be lost including network encryption information, MAC Address filtering information, and any SSID information you have entered.
  • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  • You will need your user name or password to reconfigure the unit..
Thanks, Joe
Feb 18, 2011 | Westell Wirespeed VersaLink...
I have a westell versalink 327w wireless router and i need the hard ware to install it where do i get it at.
You do NOT need hardware to install the versalink other than an ethernet cord and the phone cord. By default, you can also use the wireless antenna. The default WEP key and SSID are located on a sticker on the bottom of the DSL gateway.
The ONLY reason to need the software cd is if your ISP has installed a redirect page. There are two ways to disable it- one go through the activation page, or two: in your browser address bar type 192.168.1.1/*insert name of ISP, like verizon*/redirect.htm
It should ask you for the user name and password- by default it is admin and password. You should see a page that has something along the lines of "Select button to disable"- press it, then the modem goes into it's setup pages. No tools necessary. No CD necessary. The only time you NEED the CD is if you are trying to connect via USB- I do not recommend this, since not only is ethernet more reliable, it's faster and does not require an unstable driver added onto your system.
Also, since I suspect you are a Verizon customer (they are the ones that supply the 327w for the majority- Contact Verizon technical support. For the business side it's 888 649 9500, option tech support. They can walk you through setting up your modem as well as send a cd for the modem *if you need to use the modem via USB*
Sep 23, 2010 | Gateway Computers & Internet
I need the mms settings for my samsung f480 for t-mobile here in the states.
Server Name: T-Mobile MMSC
Gateway: 216.155.165.50
Port number: 9201
Server address: http://216.155.174.84/servlets/mms
Cnnect via: My Work Network
Sending size limitation: 100k
WAP version WAP 1.2
You need to make sure that you have a connection under the My Work Network set to the apn name wap.voicestream.com.
OR:
Port number: 8080
Sending size limitation: 300k
WAP version: WAP 2.0
***Make sure the port# is 8080, and that this is set to default
For "My Work Network":
APN: wap.voicestream.com
Proxy Settings:
- This network connect to the Internet (checked)
- This network useses a proxy.... (checked)
- Proxy Server: 216.155.165.50
Jan 25, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
We have a westell, model 327W and do not have the security code or the one we have does not work. Whar do we do?
Access the setup page through a web browser on a wired computer. In the address bar, type 192.168.1.1.
Default Username: admin
Default Password: password
If this doesn't work, try admin for the username and password. If still doesn't work, then you will need to reset the gateway. Take note that before resetting the gateway, you need to know the internet connection settings. Resetting the gateway will restore the settings to default.
Once you are in the setup page of the gateway, go to Configuration> Wireless> then look for the wireless security. It should show you the WEP key.
Enter the wep key on your laptop.
I hope this works! Good luck!
Dec 22, 2009 | Westell Wirespeed VersaLink...
I want to turn wireless option off
the default username and password on them is
username: admin
password: password
Aug 22, 2009 | Computers & Internet
Can not send or receive multimedia messages.
Maybe internet is shut off on your phone?
Here are the internet settings for Cingular: Internet Setting Cingular:
Profile Name: Cingular
GPRS setting:
APN: wap.cingular
User Name: WAP @ CINGULARGPRS.COM
Password: CINGULAR1 (ALL UPPERCASE)
Time Out: Off
Primary Gateway IP: 66.209.11.61
Port: 9201
Secondary Gateway IP: 0.0.0.0
Port: 0
DNS Server:BLANK
CSD setting:BLANK
Dial in number NONE
Query at Logon: (NO CHECK MARK)
User Name
Password
Baud Rate Auto
Line Type: ISDN
Time Out Off
DNS Server:
Then go to your browser and enter the following settings:
Profile Name: MEdia Net
Homepage: device.home
Network Link: Cingular
MMS Settings:
Profile Name: MMS over HTTP
MMSC: http : //mmsc.cingular.com/ (No Spaces)
Max Sending Size: 30K
Network Profile: Cingular
and T Mobile: Internet Setting T-Mobile
T-MobileWeb Settings:
Primary IP Address: 216.155.165.050
Secondary IP Address: (Blank)
Access Point Name (APN): wap.voicestream.com
Data Bearer: GPRS
Profile Name: GPRS
Username: (Blank)
Password: (Blank)
Home Page: http://wap.myvoicestream.com
Picture Messaging Settings:
Multi-Media Service Center (MMSC) Address: http://216.155.174.84/servlets/MMS
Validity Period: 72 hours
Hide ID option (if option exists): set to off, no, or disabled
and Fido: Internet Setting FIDO
Profile name: FidoWAP
GPRS setting:
APN: wap.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.11
Port 8080
Secondary Gateway IP: (blank)
Port: (blank)
DNS Server: (unchecked)
CSD Setting:
Dial in number: (blank)
Query at logon: (unchecked)
Username: (blank)
Password: (blank)
Baud Rate: Auto
Line type: Modem
Timeout: Off
DNS server: (unchecked)
Then press Save.
To get MMS working (what I haven't included are the blanks and all boxes should be unchecked unless specified)
Setup-->Data Network
Profile Name: Fido MMS
APN: mms.fido.ca
Username: fido
Password: fido
Timeout: 15 minutes
Primary Gateway IP: 205.151.11.13
Port: 8080
Baud Rate: Auto
Line type: Modem
Timeout: off
Then click SAVE.
THEN
Messages-->Service Setup-->Multimedia Message
Default profile: FidoMMS
(all other settings are to your preference)
Tap the box beside Default Profile and ensure that FidoMMS is the default profile.
Settings for MMS profile goes
Profile name: FidoMMS
MMSC: http://mms.fido.ca
Max Sending Size: (your preference)
Network Profile: Fido MMS
and Rogers: Internet Setting Rogers
Proxy Name: Rogers MMS
Proxy Address: 172.25.0.107
Access Point: Rogers MMS
Home: ((Set whatever page you like here))
Port Number: 8080
Authentication Type: HTTP-BASIC
User Name: media
Password: mda01
Access Point Name: Rogers MMS
APN: media.com
Authentication Type: PAP
User Name: media
Password: mda01
DNS: <>
Linger Time: 180
MMS Accounts (Main Menu -> Messaging -> Messaging Settings -> MMS Settings)
Profile Name: Rogers MMS
Proxy: Rogers MMS
Relay Server URL: http://mms.gprs.rogers.com
Feb 19, 2009 | LG Shine KE970 Cellular Phone
Westell Wirespeed VersaLink (A99-327W11-00) Router (A99327W1100) Logo
Top Westell Wirespeed Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Westell Wirespeed Computer and Internet Expert? Answer questions, earn points and help others
