Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Problem for Frigidaire 30 in. Electric Gallery Series Self-Cleaning...
THE OVEN TEMPRATURE IS NOT CONSISTENT.
By stufus78 on Oct 05, 2009
THE OVEN TEMPRATURE IS NOT CONSISTENT.IT KEEPS BURNING FOOD.
Solution #1
posted on Oct 05, 2009
Not Rated)
fixyourboard
Rank: Guru
Rating: 91%, 28 votes
Usually this is due to a bad temperature sensor. Sometimes it's due to a control board malfunction.
If you can get an accurate measurement of the oven temperature (which is not as easy as it sounds) you can do some diagnosis from the outside:
You need an accurate thermometer or thermocouple into a DVM. Make sure there are no obstructions in the oven (baking sheets, etc). Make sure you are measuring the temperature in the center of the oven cavity.
1. If the average measured oven temperature agrees with the display, the sensor is probably ok. The controller cycles the element on and off, at a rate that results in a correct average temperature. So you have to record the thermometer reading min and max over several cycles.
2. If the sensor seems ok from #1, it can be verified by disconnecting it and measuring its resistance. Should be 1080 ohms at 70F.
3. If the sensor seems ok, but the oven temperature is erratic, then it's probably a control board issue. We repair these at www.fixyourboard.com
Was this helpful?
Yes
No
Popular Solutions for Frigidaire 30 in. Electric
Questions and Unsolved Problems for Frigidaire 30 in. Electric
Do you recommend Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven?
Answer
Answer
My landlady decied to "fix" some electrcal issue in the building. I beleive I heard her... (More)
Answer
I have and old frigidaire refregarator and the cord is cut and I want a know if the current flow can... (More)
Answer
Hi, I have a frigidaire 27 inch wall oven and every time I use the cleaning cycle the oven quits... (More)
Answer
I have a "locked" indicator for my oven and i'm unable to unlock it
Answer
What is the power in watts of each of the oven (not top burners) coils in the ES340 oven section?... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Ovens Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
