Question about E-Machines eMachines Desktop PC
I have a emachine w2925 and when I tune it on. It just beeps and will not boot up
  • jlstevans Oct 06, 2009
    one beep constant
  • Taniela Matai
    Taniela Matai May 11, 2010
    how many beeps
    Scholar:
  • 82 Answers
If you have the manual, the specific sequence of beeps might tell you what the problem is. Beep codes vary by bios and manufacturer so I couldn't tell you what they mean without a maual for your specific model. Anyway, the 3 most common reasons are bad or loose memory or bad video, or bad power supply. You can try removing the power cord from the pc and open it up and reseat the memory but the other problems, you'll probably need a tech to look at to verify the exact fault.
Posted on Oct 05, 2009
Testimonial: "thankyou for your help i will have to get the manual"
Emachines el1352g-01w beeps while booting up
be sure nothing on you keyboard or pressing any key
Dec 04, 2012 | eMachines EL1352G-01w (884483537679) PC...
Need wiring connection diagram for Power Switch to Motherboard for EMachine W2925 model. Wires were disconected accidentally while cleaning inside of tower
micha219, the eMachines W2925 desktop computer uses an FIC motherboard.
First International Computer { Inc }
The Model Number of the FIC motherboard is VC37.
FIC VC37.
Disregard the following if you are aware:
The plastic front of your computer is the Front Panel.
The area on the Motherboard that the cables (Wires) from the Front Panel connect to, is the Front Panel header.
Processor to the Top, Ram Memory slots to the Right, the Front panel header is in the Bottom Right corner.
It is a rectangular shape with two columns of pins.
The length goes up, and down on the motherboard.
The pins on the Right side of the Front Panel header are numbered Odd.
The pins on the Left side of the Front Panel header are numbered Even.
There are 4 pins on the Left side.
There are 5 pins on the Right side.
Starting at the Bottom on the Right side going Up;
Pins 1, 3, 5, 7, and 9.
Starting at the Bottom on the Left side going Up;
Pins 2, 4, 6, and 8.
A) Pins 2 and 4 are for the Power On LED light.
(If after connecting the LED light is dim, reverse the wires)
B) Pins 6 and 8 are for the Power On switch. (Power On button)
C) Pins 1 and 3 are for the HarDDrive Activity LED light.
D) Pins 5 and 7 are for the Reset switch. (Reset button. IF used)
Pin 9 is NC. Not connected
Oct 18, 2010 | E-Machines eMachines Desktop PC
Emachine w2925 celeron 330 when turned on getting a single continuous beep
I would replace your ram.....Most often this is the problem...Most likely PC2700 DDR
Apr 06, 2010 | E-Machines eMachines Desktop PC
Emachine starts boot process but stalls, no beeps
most likeley if you see something on the screen but it wont boot it is a mem problem, does it load bios, if so it is prob not memory
Nov 17, 2009 | E-Machines eMachines Desktop PC
Every time I put in new memory in get a beep code error
Although your machine lists up to 2GB of RAM memory, what they don't tell you is that in most cases, you need to have a 64 bit version of Windows installed to utilize the additional memory. Odds are very good that you have 32 bit version of XP installed. Try installing just 1 stick of 1GB and leave the other slot blank and see if the machine will boot.
Oct 18, 2009 | E-Machines W2925 PC Desktop
On boot up the emachine now beeps every 5 seconds
Reboot with "F8" held down.
you are only booting to bios and minimum disk software. This may give you an indication of your monitor or video driver status.
If you can borrow another monitor from someone, that would confirm your monitors status....
Oct 14, 2009 | E-Machines eMachines Desktop PC
Wiring diagramfor w2925
here's a link to emachines' webpage with the user's guide in pdf format to download.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W2925
or download it directly here
http://downloads.emachines.com/userguides/DesktopPC_UserGuide_en.pdf
You must have a PDF reader installed or you can use this snapshot form its Page 19 - PC Desktop Back
The cable from your monitor must connect to the Monitor port (middle and right on picture). Be CAREFULL not to force the connection. The cable only fits one way and you can damage the pins if you force it. If it won't plug in easily, then rotate the plug 180 degrees and try again.
If your connection seems inadequate, you may have bent one of the pins. If you suspect a bent pin, look into the end of the connector on the cable to see if one or more of the gold colored pins are bent. You can straighten the pins yourself with a needle-nosed pliers or a small blade screw driver use gently, otherwise try to get a replacement monitor cable.
Sep 13, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
139 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
