Question about Kenmore 84052 Dryer
I have a Kenmore electric dryer series 80...It tumbles but suddenly no heat??? I need to check the fuse but I don't know how to get at it? I have the back TOP panel off & it has a piece of paper with a legend which is great but I need help w/ interpretation. The only thing I read about a fuse is it says on that legend "thermal fuse not resettable 196 degrees"...Then all the way to the left of the upper back panel is a panel that resembles fuses maybe as it looks like the small car fuses I have seen...Can you help me find the fuse??? Thanks so much...Sincerely Sue
    President:
  • 1,304 Answers
First its not the fuse or thermal fuse
if that was bad you would not get tumble
it is your heat package
remove the back panal, lower right is you heat
making sure the unit is unplugged disconnect the heat 3-4 wires and one 5/16 nut on the left lip
take out the heat and visualy inspect,,,
Posted on Oct 06, 2009
Kenmore 80 series dryer does not hest
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Gas Dryer---
2. Check for the continuity of the heating element in your gas dryer using a multimeter. Replace the element if continuity is not there.
3. Inspect the thermal fuse if it is burnt out, it is attached to the exhaust duct on the back panel of the gas dryer. Replace if necessary.
4. Check the igniter by first disconnecting it, and then place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance, if it is above 100 then replace the igniter.
5. Check the continuity on the flame sensor. The sensors are usually located close by the igniter so are easily visible.
Hope this helps...
Daniel
Sep 25, 2010 | Kenmore Dryers
Kenmor 80 series gas dryer model # 11076822695 dryer is heating up for about 2 min then it gose cooled for the rest of the cycle
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Kenmore 72802 Gas Dryer
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
My kenmore (80 series)clothes dryer is tumbling and the motor is runing but the heat is not working. what can i check or replace to slove to problem. Thank you for your time.
First, make sure that there is no ventilation issue and that the vent is clean and clear. If the dryer isn't heating, check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. Both components are located in the rear of the dryer. The thermal fuse is about an inch long and is usually attached to or near the exhaust duct. Remember to disconnect the dryer from the power source before attempting any repair.Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Kenmore 62602 Electric Dryer
Kenmore series 80 gas dryer tumbles no heat
Yes. If the thermal fuse has no continuity, then the fuse is bad. Replacing it should get you back in action, barring any other defective items like the heating element, etc. Best wishes.
Aug 17, 2009 | Kenmore 73952 Gas Dryer
Kenmore 80 series HD+ dryer will not heat. dryer runs and tumbles fine just no heat
Check thermal fuse behind the dryer by opening the back cover.Fuse is on the air duct.
Jun 18, 2009 | Kenmore Dryers
My Kenmore 80 series electric dryer won't heat. I
The bottom limit is engineered to open at 250F and the small top one is supposed to open at 300F. The bottom did not have time to click in and so it is considered weak. the kit comes with both thermostats in it Part number 279769
Mar 07, 2009 | Kenmore Dryers
Kenmore series 80 Gas Dryer: No heat
ck the thermo fuse then ck the gas valve for power and the igniter to see if its broken probley igniter if you dont see a glow comeing from it
Mar 18, 2008 | Dryers
Kenmore 84052 Dryer Logo
838 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
