Menu screen keeps popping up cant turn it off RCA r52wh74
  • 5,138 Answers
On your front panel board where you press on/off ch+ch- vol-vol+ the Menu contact switch is either dirty or defective,Clean all front contact swiches or replace them Clean with contact cleaner only for Parts Call Mats 1-800-628-1118 This another problem RCA has with these TVs.
Posted on Oct 05, 2009
I nned to know how to change the aspect of the screen on my RCA R52WH74
go to menu and then picture settings to change the aspect ratio either 4:3 or 16:9 settings.
Oct 10, 2012 | RCA Televison & Video
I have an RCA 52inch rear projection tv model No#R52wh74 when i turned on the set the screen went into some concave mode and the color is al distorted what do i need to fix this
DO you have convergence in the customer setup menu? if you do not then check out the article fl231 problem in the tips and tricks section
Apr 28, 2009 | RCA R52WH73 Projection Television
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
RCA R52WH74 Circuit Board
when the menu keeps poping up it ussally the front panel cuircit board. This is the board that the front button are on. to remove the board you have to remove front bottom panel then remove the center panel. these panel are attached with about 4 torx screws on both sides the 4 torx on botom of center panel and two on each side..
Jan 06, 2009 | Televison & Video
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca
have you looked on ebay
Jun 19, 2008 | RCA D52W19 52" Rear Projection Television
Televison & Video Logo
170 people viewed this question
Top Televison & Video Experts
Electro Med Services...
