Question about Sony Cyber-shot DSC-W50 Digital Camera
Camera lens goes out and in
Yes, mine's like that too.
so how do we solve itt ?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Sony Master
  • 102,366 Answers
Try the procedure in this tip.
Posted on Jun 06, 2012
Hello.. My the autofocus on my xsi is not working.. it sounds like the lens is not catching in a way.. like, the camera is asking it to focus but the lens isn't moving at all... it makes the sound it...
Yes sort of, we have several possibilities first is that if the lens is equipped with an auto and manual switch the switch may have been set to manual or it's positioned between manual and auto focus. Failing that I'd suggest you turn off the camera release the lens from the body and reinstall it making sure the lens has fully locked and you hear it click into place. Remove the battery from the camera for a few seconds and re-install the battery and turn the camera back on. hopefully all will work for you again. Failing this I'd say you have foreign material caught up in the lens barrel like sand dry dust, lint from a fuzzy glove. If that is the case then the lens would need service and cleaned.
Dec 20, 2010 | Canon EOS Rebel XSi Digital Camera
Camera says lens error and I don't know how to solve the problem
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 09, 2010 | Nikon COOLPIX S51 Digital Camera
I want to take a very very clear snapshot of the vehicle so which c mount camera may i use and where it will be available
are referring to a moving vehicle? if yes, your zoom lens above would just be okay. i suggest that you set your camera to Time Priority and select at least 1/40 to have blur background. The key is to lock on the moving vehicle to the panning of your camera by twisting your body to the direction of the subject. This link gave some pointers to do this: http://photography-on-the.net/forum/showthread.php?t=426114
Oct 06, 2009 | ITT 60-300mm C-Mount Lens
Powershot e1 says lens error, restart camera and won't work
Were you at the beach? If so, it more likely started when a single grain of sand clung to the side of the camera's lens barrel while it was being closed.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 10, 2009 | Canon Powershot E1 10MP Digital Camera...
Lens clicks but will not close. It says lens error restart camera
I have the same following problem before. It may cause you drop it and the lens stuck. Try to push your lens. Mine solved after doing this =]
Jul 07, 2009 | Canon Cameras
Camera malfunction
mine is doing exactly the same arrrrrrrraaaaaahhhhh
Apr 25, 2008 | Olympus SP-350 Digital Camera
When i turn camera on shutter closes and lens goes inside, and other way round...
Try the Sony web site technical help. but I feel that there is a main board fault developed here- perhaps time for a new camera try the tech help first though
May 28, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Camera switches itself off seconds after turning it on
This is a service center job and I think the lens assy motor is jammed. Take to a near by camera repair center
Feb 04, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Turns on but that's all
Oh yes the Sony Click When the camera powers up it must run a duty cycle to check that all circuits and the lenses are functioning properly. What you are hearing is most likely the gear assembly on the lens is out of time. one gear reaches its limit the motor doesn't know because another component is not is the proper orientation and on gear clicks over another. Never reaching the end The software does not get the information that everything is okay and does not allow the camera to function. Suggest professional Repair.
Aug 02, 2006 | Sony Cyber-Shot DSC-P52 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
