Question about Poulan Garden
The chainsaw starts fine but only works for 10 minutes then stalls out. It can not be started again. I will wait a week and it will do the same thing. I checked/cleaned the spark plug and looked at the fuel lines for anything foreign in the gas that might choke the supply. Nothing. Any help would be appreciated.
    President:
  • 2,220 Answers
When it starts to starve out loosen the fuel cap. If it smooths out and runs properly you have a plugged fuel vent. Get back to us with this information and the model number. We can probably help repair that too. GL
Lou
Posted on Oct 06, 2009
  • dontbother10
    dontbother10 Oct 06, 2009
    If not a vent problem it might also be a coil that quits once hot. Fuel delivery problem is usually slow, you have some time to react. If it just quits with little warning try this very soon after it stalls. Sometimes they quit once hot.
    Ignition Coil Test
    SmallEng.com
    http://www.youtube.com/watch?v=L7WNBDRG4...
    You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode.
Ford excursion 2002 - starting fine but losing power and stalling after running for 10 minutes. Rest for about 5 minutes, then starts up again
Can you perform a spark test? I would like to know if it has spark when it stalls. Also, if you have a can of starter fluid, wait for it to stall and not want to restart, the quickly spray some starter fluid into the intake. If it runs on the starter fluid, you have a fuel issue. You might also want to make sure the engine coolant level is fine and you aren't overheating. If you coolant level is low you may not know it is overheating since the coolant sensor isn't in coolant. It won't read air.
Jan 28, 2014 | Ford Excursion Cars & Trucks
Programing a key fob
1. Perform a security system relearn.
2. Let the vehicle sit for more than 10 minutes with the key off.
3. Attempt to start the engine, leave the key in the run position monitoring the security system indicator.
4. After 10 minutes, the security indicator will change state.
5. Turn the key off and wait 10 seconds.
6. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
7. After the second 10 minute timer has expired, turn the key off for 10 seconds.
8. Attempt to start the engine. If the engine stalls, wait another 10 minutes with the key on.
9. After the 3rd 10 minute timer has expired, shut the key off for 10 seconds.
10. The security system will relearn on the 4th starting attempt and the engine should start and run.
If this doesnt work, you may have a failure in your system. If the security light is on, and the reprogram doesnt work, you might want to look into bypassing that antitheft system.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Aug 06, 2011 | Oldsmobile Alero Cars & Trucks
How to reprogram key
If this doesnt work, and you are having STARTING issues, go to this link.
Jul 29, 2011 | 2005 Pontiac Grand Prix
1992 Oldsmobile custom cruiser stalls and won't start
Sounds like its not getting enough air then overfeulling .
Check the air mass sensor and air meter. also check all the pipes from the air box for splits etc.
Jan 22, 2010 | 1992 Oldsmobile Custom Cruiser
Stalling
Possibly faulty ignition module is the problem, stalls when engine is hot when you sit for a while it cools off and runs again until it heats up again, those are usually the symptoms of a bad ignition module and after a while it may give out all together and not run at all, usually if the module is at fault it shuts down the fuel pump so the engine don't load up with fuel, do to when engine continuously cranks over the injectors never stop squirting fuel and flood the engine do to lack of spark which is produced by the module, this could possibly be your problem.
Nov 01, 2008 | 1998 GMC Sierra
Same thing here...
sounds like a restriction some where in your fuel system example dirt or anything that might get in your system check your filter and look for contamiation or possilbly a airation problem
Aug 22, 2008 | 1998 GMC Sierra
Garden Logo
80 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
