Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
Have a broken belt - Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
    Problem Solver:
  • 5 Answers
There is a guy on ebay that has only 1 size, but is is the most popular. Search for "footballcardcellar" as the id.
Posted on Apr 20, 2010
  • 6,927 Answers
NAPA auto parts has replacement belts for cambel hausfeld compressors.Take the old belt with you,The part number will be like a 5177 or a j6 something.Just remove the cover,and loosen the motor to put the new belt back on,pull the motor to where the belt is firm ,but not to tight.Then you are ready.
Posted on Oct 05, 2009
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Hotpoint dryer won't stay on
    The belt is probably broken. Their is a broken belt switch which keeps the main wire winding from working if the belt is broken. To check for broken belt open the door and remove the screws holding down the top. Remove the top, then take the front off and inspect that puppy. Here is my crappy video:
    Apr 27, 2013 | Dryers
    Broken belt dyson Dc41
    Belt was broken, so I had to go inside the motor assembly -- torx screws all the way. The problem is finding a replacement belt without buying a whole new power drive.
    May 03, 2012 | Vacuums
    Does the timeing belt have to be on for the crank to turn the cam when instilling the timeing belt?
    Are you replacing a broken timing belt? Or are you replacing a belt because it's due by miles? If the belt is broken, i strongly suggest inspecting for bent valves. Daewoo is notorious for bending all valves and breaking valve guides in the cylinder head when the timing belt breaks. The broken belt is also common.
    Aug 05, 2011 | 2000 Daewoo Nubira
    Dyer will not turn on. Can hole the starter button in and dryer will run. remove and the dryer will stop running. When holding the start button the dryer does not heat. Any Idea's as to what may be...
    broken belt or broken broken belt switch most likely. Open the door. Hold in the door switch and push the start button. Does the drum turn? If it does turn then the broken belt micro switch is where I would look first. If the drum don't turn of course I would replace the broken belt.
    The only Kenmore dryer that has a broken belt switch is the 4 wheel drive model. Here is a video which shows how to get into this dryer and replace the belt:
    Jul 08, 2011 | Kenmore 63932 Electric Dryer
    Ac belt broken. Is car safe to drive? How hard is this belt to replace?
    as long as the water pump, alternator, are working properly. but if it has just one serpintine belt that drives all things it must be replaced. before running. if only the ac belt, it is ok to drive if it has its own belt that is broken.
    Aug 13, 2010 | 1995 Isuzu Rodeo
    Dryer heats up but the inside doesn't turn.
    a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
    Nov 05, 2009 | World Imports Belle Foret N30002TB...
    Drum won't turn when started
    Probably a broken belt ... search broken belt here and you will find the answer.
    Oct 26, 2009 | Dryers
    Press the start button and drum doesnt start but the dryer makes a humming noise.
    motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
    UNPLUG POWER CORD TO DRYER.
    open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
    Oct 23, 2009 | Dryers
    Broken belt unkown model number.
    if it is a newer machine whirlpool does not use belts they use couplers, if you need tech assistance live go to www.whirlpoolpartssurplus.com
    Jun 23, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
    Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
    301 people viewed this question
    Top Campbell Hausfeld Air Tools & Compressors Experts
    John Trevino
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
