Question about Olympus Stylus 710 Digital Camera
Hi.. My Olympus Stylus 710 camera is one year old
Hi.. My Olympus Stylus 710 camera is three years old and I have been having problems with it recently. Basically the camera is unusable right now. When i press the power, the lens open halfway, the picture on the LCD is blurry and one second after the lens close and an error appears of the screen saying "D: 5e02". I live in Dominican Republic. My name is Guarionex
4 Suggested Answers
SOURCE: Olympus Stylus 710 Problem with lens
Hey,
Westfield46 was right! I tried the recommended fix and it worked! Thanks so much. It turned what I thought was a piece of trash into a usable camera.
Camera Man
Posted on Aug 17, 2008
  • 479 Answers
SOURCE: olympus stylus 710 whirring, 5f08, 5e02, blurry
lens could be off track.. needs repair
Posted on Sep 09, 2008
  • 11967 Answers
SOURCE: Hi.. My Olympus Stylus 710 camera is one year old
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 02, 2009
Olympus 710 flash won't work
have you tried resetting your camera to initial settings. please refer your user manual to reset it
Jul 21, 2009 | Olympus Stylus 710 Digital Camera
Olympus Stylus 710
Following are the instructions to send your camera to Olympus for service. http://olympusamerica.com/cpg_section/cpg_servicerepair.asp Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $76 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Jun 07, 2009 | Olympus Stylus 710 Digital Camera
How do I replace an Olympus Stylus 710 Battery Door?
Please visit this site and order a new batterydoor for your Olympus camera www.lutoncameras.co.uk
regards Rob NL
Apr 15, 2009 | Olympus Stylus 710 Digital Camera
OLYMPUS STYLUS 710
error code is associated with the lens port... usually when the pressure against the lens when turning on
Dec 16, 2008 | Olympus Stylus 710 Digital Camera
Olympus stylus 710
Contact Olympus support
This may ge a generic failure and the camera will be replaced.
Anyway they are the folk who know.
Aug 08, 2008 | Olympus Stylus 710 Digital Camera
Can't transfer photos
Remove the Camera software'
Windows does not need it- it can do it all by its self.
Jul 17, 2008 | Olympus Stylus 710 Digital Camera
OLYMPUS U770 SW TOUGH CAMERA / Olympus U770 SW -Camera 2007
You should be able to order what you want from most any photo products supply store. You can also get in contact with Olympus directly, and enquire for a local dealer for what you need. '
Jerry G.
Jul 01, 2008 | Olympus Stylus 710 Digital Camera
Olympus stylus 710
I have aproblem with my stylus 710 digi cam an error saying that 5fo8 on screen pls, help me to solve my problem.ty
May 15, 2008 | Olympus Stylus 710 Digital Camera
Zoom not coming out
Unfortunately I have this problem as well. Sadly, my warantee has expired (camera is three years old). But this is what works for me: Turn on and off and repeat as much as you can. It should break loose of whatever is holding it after a while (sometimes it takes a long long time).
Good luck, hope it helps!
-Tufts
Dec 30, 2007 | Olympus Stylus 710 Digital Camera
Olympus stylus 710
I just wanted to follow up that we ordered the replacement part from the website another poster listed:
http://www.digitalcamerapartsdepot.com/Olympus_Parts/VK127200.asp
The part came in three days and it was SO EASY to replace. You just need a tiny Phillip's head scewdriver and about three minutes. Remove the three small screws that attach the faceplate to the camera (one on the bottom, two on the side). The faceplate pops right off and exposes the hinge that holds the battery door in place. Remove the final screw that holds the hinge in place. Reuse the original spring, pop the new door in place and then replace the faceplate.
Just like new! :)
Nov 09, 2007 | Olympus Stylus 710 Digital Camera
Olympus Stylus 710 Digital Camera Logo
91 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
