Question about Toshiba Satellite A25-S3072 Notebook
Cooling system hi, one day i turn on my laptop and itsaid my cooling system has a problem please shut down emediatly,so i shut it down and about 10 minutes after,. i turn it back on,and i relized that it was getting very hot, then the cooling system warning came up again,them the laptop said automactic shut down and it shut down by it self. so i opend it and check the fan the fan was perfect,so i say if it isnt the fan it has to be the penthium 4 prosessor,so i carfully took it out and tried to get another one but i got a used one with i didnt have much history about and tried it,when i tried it nothing showed up on the screen but the laptop was on tho, i took it back out and put back in the old one and it still showed nothing on the screen but was on. what do you think is the problem
  • 383 Answers
Computer hardware related downloads Operating System:, Windows 95, Windows 98. Description:, CPUCooL is a multifunctional utility: 1) Cooling the CPU under Windows 95 / 98.
Read instructions, Good Luck, Please dont for get to Vote/Thank You.
Posted on Dec 23, 2007
I have a IBM Think pad laptop running Windows xp that keep shutting down, it go through the POST OK. then 2-3 minutes it shut down. The fan is OK, and the cooling system is ok, so what do I do next.
Hi
its either a software problem or a hardware problem
normally over heating shuts down older style laptops
try using a lap top cooling pad
sometimes its a faulty hard drive
Try reinstalling XP windows again
cheers
May 21, 2015 | IBM Computers & Internet
I have a Compaq NW9440 Mobile Workstation - it keeps shutting down every 15 minutes or so. At times, it will not restart right away. I thought it may have been the CMOS Battery, so I replaced it. It's...
The most common problem you get with a laptop is overheating, this can cause for it to shut down while operating to prevent more damage.
You will know if your laptop is overheating if it happens one ore more of the following:
-The keyboard and the bottom of your laptop are very hot when the laptop is working.
-The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
-The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
-The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner.
If it is not overheating, then it is a hardware failure. Could be the RAM memory, or the motherboard. You can only corner the problem by testing with different RAM modules or motherboard.
Dec 01, 2010 | HP Compaq nw9440 Notebook
The fan wont turn off on my 1997 catera
wait 10 minutes after you shut the car off - then remove the negative side of the battery - wait 30 minutes then reinstall and run the car 30 minutes.
If your cooling fluid is full and other cooling systems are in place and working - you should be fine.
The fan on your cooling system is made to continue to run once the engine is shut down if it is running a little [ or a lot] hot. So don't panic if it runs 5 minutes after you shut the car off.
Apr 01, 2010 | 1997 Cadillac Catera
Toshiba Satellite A100 Win XP O/S. SHUT DOWN Prob.
sorry to say but sounds like a cooling problem or the bored is bad :(
Dec 29, 2009 | Compaq Presario 1200XL104 Notebook
Shuts down
Hi..
If the laptop shutdown maybe it cause overheating.
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Good luck !!!
Regards
PCmania
Jul 15, 2009 | HP Compaq Presario V6000T Notebook
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
Laptop shutting off
There might be a setting in the BIOS that shuts down the computer when the processor gets too hot. so, getting better cooling or turning off the setting will stop it. but, if you disable the setting, the Processor could overheat and explode.
Jun 11, 2008 | Gateway 7320GZ Notebook
Lenovo laptop shutdown suddenly after working for a while
Hi James, replace the fan or If it's still under warranty have it serviced. Suggest you stop turning it on until the fan is replaced. It could be the fan cooling the CPU. You don't want it to fry.
The shut down process is normal when over heating is detected by the system.
lenovo link. http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-63446
Mike
Mar 24, 2008 | Computers & Internet
Shut down after 10 minutes
it is reaching the correct temperature and then switches back on when cools a bit?
Jan 11, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Toshiba Satellite A25-S3072 Notebook Logo
196 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
