Question about Honeywell Heating & Cooling
I have 3 zone valves in my house and even when they are turned off the heater keeps turning on whats going on ?
  • 308 Answers
It could be a couple of different reasons. It is possible that even though the thermostat is not calling the end switch on a zone valve may be stuck. Is there a zone that is warmer than it should be? Another thing, depending on the frequency of the cycling it could be a normal part of operation. (the boiler may maintain a low limit)
Hope this helps
Posted on Oct 05, 2009
Niagara delta 30ff combi boiler, 13 years old. problem when the hot water for bath heats, the radiators in the house also starts heating, even after central heating thermostat is switched off.
sounds if your zone valve isn't closing off and the circ pump runs all the time ?? ck to see if zone valve gets power all the time or only when thermostat calls for it , if power is only there when called for then your valve is bad (common)
Jun 02, 2017 | Water Water Heaters
Why the hot water temperature couldn't reach the set temperature (130 degree) in Amtrol WHS80Z indirect water heater?
I have a couple of thoughts. You may have air in the boiler water circuit at the loop that feeds the tank. You'll have to find the vent in the loop to get it out. Second, the automatic valve that opens for hot water may not be opening fully. Have you felt both the boiler water lines that go in and out of the tank? If the water going in is hot and the line out is very cold you have very little boiler water going through the loop. Make sure the isolation valves on the loop are open. Is your boiler full of water? If the boiler loop lines are hot going in and coming out, the tank is full of rust or debris and no water can get to the fins on the internal tubing to pick up heat. If that's the case there is no repair and its time to get a new tank. Hope this helps good luck.
Nov 04, 2014 | Amtrol WHS-80Z - WHS-80Z 80Gal Hot Wtr...
I have a Weil-McLain hot water boiler for baseboard heat. The system has one circulator pump. The system has 5 zones - 3 work fine and two are not working. All the zone valves and thermostats are...
Hello.Prob#1 valve has a bad END SWITCH,change the power head,thad brings the circ on when open.Prob#2 try manual overide lever.iS IT TIGHT OR SMOOTH?DOES IT JUMP/SNAP?motor very hot? all bad signs.Change that power head too.The transformers are OK because 1 trans can only run 3 valves max.
Sep 20, 2010 | Honeywell (CT62B1015) Baseboard Heater
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
I have 2 zone heating - my one zone, the heat keeps running, doesn't stop at indicated temp, the other zone works fine
Hi the zone valve could well have a blockage in the valve seating you turn off either side the valve and remove the body to check in side , and see what is in there.
Mar 18, 2010 | Honeywell Programmable Thermostat Heater
Water Heater Keeps Going Off
is there a check valvle on hot water side of heater,a flow restriction of some sort, water pressure to the heater, a filter in the line, line pressure in the heater kicks out burner, when you turn on the water, line pressure drops, heater comes on, when you turn on water in other part of house, heater should not fire, so there has to be a check valve somewhere,in heater?
Jan 24, 2010 | Noritz 6.9 Gallon Residential Tankless...
Valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Amtrol water heater WH-7P gets barely warm water
From what you are saying it sounds like an issue with either a circulator pump or a zone valve. It depends on what type of system you have ... if you have a circulator pump that only runs the Amtrol then that is probably bad. If you have a zone valve system then it is probably the zone valve if you still have heat for the rest of the house. If you have no space heating then it is probably the circulator pump.
Nov 04, 2009 | Water Heaters
Tp valve opening and dumping water
Certain water heaters can only handle so much pressure from the main line. There is a pressure controller between your water meter and you house, it's called a pressure regulator. You need to call a plumber to check and see if it needs to be adjusted or even replaced.
Dec 22, 2008 | Bosch & Tankless LP Hot Water Heater
Honeywell ST6400C programmer doesn't switch off
Since you have three on/off timing modes could there be an overlap in the times?
The wires in the unit might be crossed. (don't always assume the contractor who wired maintained the correct colors , I have a friend who blew out a heating pipe because when a replacement motor valve was installed it was never wired right and the plumber assumed the colors were correct so no overtemp shutoff created steam in PVC pipes, OPPS)
There fore maybe one is still coming on. Do you have more than one heating zone? IF so see below
I guess the main question is why manually turn it off? why not use the program.
I will assume your heat is know as forced hot water heating. My house is multizoned however when the zone calling for heat turns off (zone valve closes) I installed a bypass valve in the lowest zone in the house, and reduced the circulator low shut off temp to 130 F which means even though the heat isn't on my circulator will continue to run dumping this excess heat in the lowest part of house to rise through house. (the spring loaded water valve allows the heated water to flow into this zone )We do have two thermistats. And even though the lowest one is not calling for heat the radiators are hot when the excess is dumped into this zone. So investigate and see if your system might be similar. (multizone).
Investigate your wiring, reprogram, replace any battery backup.
Dec 18, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
57 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
