Question about Olympus FE-370 Digital Camera
While using my camera the screen went black while in the auto mode. At first other modes worked and then later that day they did not either. I can see my pictures I have taken what can I do to fix this?
5 Suggested Answers
SOURCE: only works in play mode
get a new one
Posted on Jul 22, 2008
  • 326 Answers
SOURCE: how do i get out of auto mode
remove the batteries and reinsert them after a while to reset the unit.it will start in the normal mode .
Posted on Jan 31, 2009
SOURCE: Blurry Photos when using indoor or auto mode on Olympus IR-300
make sure lens is clean and be sure to use flash indoors, try using a tripod or setting camera on something and see if the results are any better
Posted on May 15, 2009
marked
  • 6487 Answers
SOURCE: The mode dial doesn't seem to work. The camera is
Base from the description of your problem what we can do here first to correct the problem is to reset or restore the camera settings to its default from the camera MENU. Then once you done that check if its working fine now.
Posted on Aug 16, 2010
Last week I was taking pictures outdoors, later on that day my screen went totally black, the green light comes on but the screen continues to stay black, I have changed the batteries
One of three possible problems. First check that you didn't accidentally press the DISP or DISPLAY button. If that's not the problem...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Finally, it could be a loose or poor connection of the screen's flex cables, a very common problem for your model camera. The A620's vari-angle screen is a great option for a camera, but with this moveable screen, the screens data and power cables can and do wiggle loose. It is actually relatively easy to fix by just reseating these cables, but will require opening the back face of the screen of your camera.Please see this other person who had a similar problem with an A630.
May 05, 2010 | Canon PowerShot A620 Digital Camera
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
My lumix camera in playback mode has on screen tv
If you can get into the menu and find "reset" you could return the camera to factory settings.
Feb 21, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
No image on lcd for taking pictures. Lcd works fine to go through also to view old pictures. just black in camera mode. Tried shooting anyway and no picture. This happened once before and went away an hour...
Nov 05, 2009 | Canon PowerShot A620 Digital Camera
First a black screen, then a lens error
For the lens error:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
For the black pictures (after you've corrected the lens error):
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Note, if you're going to try fix 5a on the above blog page, do it with the camera turned off to lessen the chance of damaging the lens.
Jul 04, 2009 | Canon PowerShot SD1000 Digital Camera
Screen become black
Try Pressing the Fn key along with the F6 key in the top row. If that works, then the system probably went into auto lcd shutoff mode. It does this to conserve power. Let me know if this works first.
Have a great day,
martyshaw152
Mar 21, 2009 | Acer Aspire 6930-6771 Laptop
Screen black in Manual mode
I had this problem, not sure how I fixed it but I think it had something to do with power saving mode. Check if battery charged.
Jul 27, 2008 | Casio Exilim EX-Z750 Digital Camera
Samsung s860 digital camera turns on and then goes to blank screen and will do nothing else, to turn off it requires battery removal. same story with new batteries.
Dear customer
thanks for ur inquiry for ur product
If the LCD screen is blank or black when you have your camera in the Camera or Play mode, the camera may need service. To determine if this is the case, follow these steps:
1. Press the Menu button to see if the LCD screen can display the OSD (On Screen Display). 2. Set your camera to Play mode, and then see if the LCD screen displays a picture. 3. To eliminate the possibility of a user setting causing the problem, put the unit into Auto mode by rotating the dial on the units exterior to Auto Mode. Note: The word "Auto" appears on the screen when this mode is activated. 4. If putting the camera into Auto mode does not resolve the problem, test the unit in Play mode. If the unit operates normally in Play mode, but the screen in Camera mode is blank, your camera requires service which you can arrange by Creating a Service Ticket below. Note: Because your camera has an automatic LCD display shutdown feature, its normal for the LCD to stop displaying when the camera has been on for along period of time. This feature prolongs battery life.
urs sincerely
Harrish
Jul 10, 2008 | Samsung Cameras
Fuji f700
I recently had trouble with the LCD Display coming up with a black screen. So I mailed it to Fuji with a letter explaining the problem. About 3 weeks later I got it back in the mail and it seem to be working fine until a month later. I turned it on and the LCD display show a black screen only now it has white lines. I'm so incredible mad and extremely dissapointed in Fuji. Reading online I have notice many people having trouble with Fuji Products. I WILL NEVER BUY a Fuji again!!!
Jan 15, 2007 | Fuji FinePix F700 Digital Camera
Olympus FE-370 Digital Camera Logo
20 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
