Question about HP Officejet 5610 All-In-One InkJet Printer
The paper feeds and prints but it prints to far up on the page
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
checkitright
  • 1362 Answers
SOURCE: HP color laser jet 2600n wont feed paper
found problem ??
Posted on Sep 08, 2008
SOURCE: paper feed grabs more than one sheet
Try fanning your paper several times. Take that nice neat pile of paper in your hands and wiggle it so that your thumb fans through the edge of the whole stack. Do this on both edges so that the stack of paper is slightly less perfect. You can also gently fold the whole stack slightly in both directions. Do this every time you add fresh paper. It should only take a few seconds.
Posted on Jun 03, 2009
Touch2Heaven
  • 145 Answers
SOURCE: LaserJet 1020 printing solid black pages
1.replace the cartridge.
2. check PCB board contacts
3. replace PCB board
Posted on Jun 19, 2009
efs_perpends
  • 1996 Answers
SOURCE: HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 03, 2009
Stops feeding paper at start of printing and repeatedly states there is a paper jam. why wont it feed and how do I get paper out as it is a sealed unit. initially paper was feeding too far thr so printing...
With out knowing the make and Model of the copier it can be difficult!
Suggest that you clean the rollers that pick up the paper with a clean lint free cloth and water.Ensure that you unplug the machine from the power point first.
Dec 06, 2009 | Office Equipment & Supplies
Deskjet 932C. Won't feed paper.
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Sep 24, 2009 | HP DeskJet 932c InkJet Printer
Paper feed problem
Try changing the bottom margin in your print software.
Oct 25, 2008 | Samsung CLP-500N Laser Printer
When printing Glossy paper 260gsm, on my HP 4280, the paper appears to be slipping in the feed roller and the image prints too far down the page. Any ideas ??
Take the back cover off, and you will see the feed rollers in there. Use a soft cloth and some all purpose cleaner and gently clean the rollers, not too much liquid on them, lat dry and clean again for couple or three times. You feed rollers have become soiled and are slipping on your paper. I have three hp printers and this must be done every couple months or so. I think I found these instructions on hp.com if I remember right.
Aug 16, 2008 | HP Office Equipment & Supplies
OKI Margins
Are you using compatible ribbons which maybe to tight try geniun OKI ribboms.
Hope this helps,
Dezzi
Apr 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Paper feed problems
Set your printing job in print preview you can adjust inexact spaces in four corner of sheet of papers./ do't print w/out prvieew
it will wasting ink and papers.
Oct 31, 2007 | HP PSC 2355 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
HP Officejet 5610 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
