Question about Garden
Engine starts and runs fine have water to machine but get nothing out cleaned inlet filter screen what next
4 Suggested Answers
woobie dog
  • 1273 Answers
SOURCE: water inlet, outlet,ok start engine lose all
Prime the pump well by connecting the water and letting it run for several minutes to get all traces of air out of the pump.
Regards, --W/D--
Posted on Jul 20, 2009
SOURCE: i have a 2300 psi
If you no longer have High Pressure coming out while machine is running, it's a pump issue.
Posted on Mar 19, 2011
pandaypira_b
SOURCE: I have a SCA 5.5HP
re http://www.fixya.com/users/qas1 : I have exactly the same problem. Have u got the solution yet?
... Darwinian
Posted on Jun 15, 2012
HOW DO I STARTS MY WASHING MACHINE AGAIN CAUSE IT ALWAYS `IE` ERROR EVEN I ALREADY CLEAN THE FILTER,CHECK HOSE,THIS ERROR HAPPENS WHEN SOMEONE USE IT MANUAL WHEN NO WATER IN SERVICE,I MEAN HE MANUALLY
The IE or E1 error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
If you are trying to use the machine manually, there needs to be enough water in the machine to tell the level sensor when to switch off the water inlet solenoid valve. Failing this, the machine will only show IE (Inlet Error) and refuse to work.
Feb 15, 2015 | LG WD-1070QDP 7 Kg Direct Drive Washer
When you start it the engine just runs and the machine doesn't fill up with water
Just beyond your filter that you cleaned you will feel some blades, plastic. These blades should turn freely, these are the pump blades, something shd be blocking it, which over flowed from your dirty filter.
Another thing is did your washer not fill with water on starting it? Well take of the power plug from the wall (imprtant before all these jobs!) turn off the washer, turn off the wall valve, unscrew the pipes to see if water flow is gud, check to see if anything is blocking your filters and he washing machine inlet valve. It has a fine filter and is detachable to clean.
Helped?
Mar 10, 2013 | Washing Machines
Where is the filter in washing machine
Start by turning off the hot and cold water faucets that are connected to your washing machine. This will stop water from running into your washer so you can disconnect your water inlets without flooding the house! To relieve any built-up water pressure, pull the knob out on your washer that starts the washing cycle for just a few seconds. Now it's time to unplug and disconnect your washing machine. First, unplug your washer from the electrical outlet. Next, use a pair of pliers to unscrew the hose fittings on the back of the washing machine. There will likely be some water left in the hoses, so you will want to have a hose or a bucket handy in order to catch and clean up any spillage. Now it's time to break out the water-resistant vacuum. Place the vacuum over each water inlet. As you turn on the vacuum, tap on the inlet a little with a plier in order to free any debris or sediment that may have lodged in it. Continue vacuuming until the inlet is clear, then repeat on the second water inlet. Now that you're done clearing out the filters, it's time to reconnect your washer. Using your pliers, reconnect the correct hose to its inlet and make sure to tighten them properly. Don't forget to double-check to see if there are any leaks. If you find any, re-tighten accordingly. After that, all you have to do is plug your washer back into the outlet and you're ready to go. You've successful cleaned out your washing machine filter!
Aug 05, 2012 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool cabrio washer starts to fill and then quits almost immediately and then the LF code comes on. I have run the automatic diagnostic test and the water inlet valve seems to work fine. During test...
Try cleaning your inlet valve filters. Turn off your water supply and remove the hoses from the washer. The filter screens are located just inside of the valves. Just twist them out, clean, and reinstall.
Good luck.
May 06, 2011 | Whirlpool Washing Machines
The engine doesnt start ,, and theres somesort of **** in the carb i think it maybr water or oil ,, but iv drained the fuel out of tank and the fuel is clean, no water nothing ,,,, this has happend 3-4...
2 Stroke Engine carburetors are very temperamental by nature. If any foreign material gets in them, there is a very small mesh filter screen under one of the covers (the pump cover) to catch the debris before it can go any further. That screen though, is located in the main fuel inlet passage. If a lot of debris has been trapped there, the machine will not start well or at all.Therefore I would recommend that you remove the carburetor, disassemble it and clean it well. Carburetor/Choke aerosol spray sprayed through the orifices in the carb can help. If this machine has 2 or 3 years of use on it, you may also need to install a gasket and diaphragm kit or a rebuild kit on the carburetor. A no-start issue can have many different causes. Here are the things that have to be in perfect working order for the machine to start.
1. Clean fuel mixed at the proper ratio (check in tank fuel filter and fuel lines) 2. Engine Compression (at least 60-110psi). 3. Clean air entering the carburetor (check air filter) 4. Strong spark (remove spark plug and while holding it against metal engine, pull on start rope). A nice blue spark is needed here.
Jan 23, 2011 | Garden
What does IE error code on LG front loader mean
"IE" is an error code that indicates a water inlet problem on an LG washing machine. This code will appear if the washer is not filled to the correct level within eight minutes after switching it on. Possible causes for the IE code include partially closed taps, improperly attached inlet hoses or clogged inlet hose filters.
Jun 21, 2010 | LG WM-2277HW Front Load Washer
What does error code 6P mean on an Amana washer model LW9203W2B
SH: Open thermistor. Unplug appliance and let rest for 15-30 minutes, then plug back in. If code continues, unplug appliance and call for service.
bP: Pressure switch error sensed. Washer will not operate when this error is displayed. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
rP: Water supply problem in spin cycle. Check for pinches or kinks in the water inlet hoses and straighten if necessary. Check the water inlet hoses filter screens and clean if needed. Verify that the water supply is turned on. Unplug washer and let rest for 15-30 minutes, then plug back in. If code continues, call for service.
LO: Lock Out mode. To activate, press START and STOP/OFF pads at the same time. To deactivate, repeat the procedure.
AU: Flashes when a factory preset cycle is put on hold. A normal function.
Clean Filter: Flashes when a cycle is selected as a reminder to clean the filter before starting a cycle for optimum drying results. Code clears when the door is closed and the START pad is pressed.
Dec 29, 2009 | Amana Washing Machines
My cold water just trickles in, is there a filter somewhere? The hot water seems fine. I don't see anything obvious that I can clean...
Hi, Romeve the inlet hose and clean out the screen inside the inlet valve.
This should take care of the problem.
Vic
Jul 18, 2009 | Washing Machines
Cold water just dribbles into GE washing machine
Unhook the cold water hose from the back of the washer. Look inside the water valve for a clogged filter screen and clean it. It the screen is not clogged, replace the water valve.
Apr 27, 2009 | GE Washing Machines
Garden Logo
27 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
