Monitor powers up but no pic. - Televison & Video
  • 22 Answers
THERE ARE SMALL FUSES IN THE HIGH VOLTAGE CONVERTER,USUALLY ARE WHITE.CHECK THEM ALL.
Posted on Oct 05, 2009
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
My screen is black since wednesday 13 october, i do everything recommanded in my user guide, and the problem still continue.
connect to laptop a external, then power it up
if you get pic on external monitor then lcd on laptop is faulty
if no pic on external monitor then its hardware problem,
could be the following
hard drive
graphics card
or the motherboard?
Oct 16, 2010 | Acer Aspire One Netbook 8.9" Notebook
Power light is flashing blue but no pic
Please verify that it does the same with other PC also before taking it apart, if it still does not work, then please read below:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 15, 2010 | Gateway FPD1975W 19" LCD Monitor
Samsung t240 monitor lost pic
This problem with the T240 (t240M or T240 HD depending on the coutry) monitor on Windows 7 and maybe on Vista
is due to Samsung´s driver witch is not updated to Win 7. You will have to lower your video
resolution to 1600X1024 (higher resolution accepted) be able to use your monitor. Unfortunately it will not work on Full HD mode on Win 7,
until Samsung releases an updated driver for win7.
I had the exact same problem here and found this information together with the samsung people.
As yet they have no idea when the needed update will be available. Hope soon, till then no Full HD resolution for us.
Cheers from Brazil
Mar 04, 2010 | Samsung SyncMaster T240HD 24" TFT LCD...
NEC 2080 UX - power light flickers - pics of appears broken caps?
you can change these, you need some soldering skills. the monitor is 3 colour sets. so they have same components on the 3 colours. so you take all is leaking out clean the liquid (sulfuric Acid), and replace with a new ones. you find the components in your local electronics stores.
Feb 09, 2010 | NEC-Mitsubishi MultiSync 2080UX (Black)...
No pic. But it powers up
In this case the monitor itself is damage. If the monitor "SELF TEST" screen appears it is working okay.
Then try checking the VIDEO CONNECTOR and the VIDEO CARD. If both are okay, then monitor itself is bad. Thank you.
Oct 05, 2009 | Computers & Internet
Dell flat pannel monitor fail to power up after power outage
rtutt, First, before you start to tear apart the monitor any further, take pic's (close-ups) of screws, cables and their positions BEFORE detaching them from their board mounted jacks. Second, the fuse will be a small pigtail type soldered to the power supply board. It's the board that will have the connector on it that the line cord plugs into from outside the plastic cover. This is Pretty neat for you because if you forget where something goes, you can always open up another monitor. Well if you get the steel shield cover removed (BE VERY CAREFUL NOT TO RIP OFF ANY CABLES OR MULTI CONDUCTOR RIBBON FLEX CABLES) the cables can then be popped off. you can probably catch a video of monitor tear-down on YOUTUBE.com by doin a search on LCD repair. Yes I have seen some that are 8 to 12min long on the tube. Also you will be visually checking all large electrolytic capacitors for SWOLLEN tops of their aluminum can. You will need a large magnifying glass to inspect the solder side of the board for circular hairline fractures around the leads of heavy and larger "through-hole components, that have been thermally/mechanically STRESSED over the years. they will need to be resoldered. Well any way, keep me posted of your progress. Im louie12fix or lmistyrel@ aol.com PS: I have dell and will take pic's of board!!
Apr 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Sony vaio pcg fx120
Try hooking up a different monitor. If that is not an option try looking for a key in the F-keys row that has a pic. of two monitors that might even say lcd on one of them. Hold down the Fn key and push the key with the pic once. If not then push the key twice before letting off the Fn key. And so on
Jan 30, 2009 | Sony VAIO FX120 Notebook
No pic on the monitor
Canon has an option to keep the pic from showing up on the monitor-go to 'clear settings' and put everything back to default.
Nov 29, 2008 | Canon EOS-1Ds Mark III Digital Camera
Wiring problem
the monitors are made by power acoustik there is a green wire a red wire and the white wire has a wire in the middle surrounded by ground wire8a804da.jpgd2d189c.jpg
Sep 16, 2008 | Power Acoustik 7 Widescreen Headrest...
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
