Question about IBM ThinkPad T40 2373 Notebook
Laptop freezes due to movement
Motherboard problem?
  • 22 Answers
LOOSE RAM OR HARD DISK.CHECK IT RIGHT NOW!!!!DON T TAKE IT LIGHTLY.
Posted on Oct 05, 2009
TOSHIBA SATELLITE L505D LAPTOP MOTHERBOARD V000185210 AMD start ok then freeze after seconds no any action what could be the reason ?
This problem occurred when your processor goes overheating due to fan and heat-sink problem.
Solution is that just clean your fan and heat-sink and then replace them. When you will start your laptop after this small service, the problem will has been removed.
Good Luck
Aug 14, 2012 | Toshiba Satellite Computers & Internet
My HP netbook keeps freezing. I don't know whether its due to overheating. But everytime when it freezes, its very hot. Another problem is, when i shut down my netbook, it always restarts by itself....
Hi xinyi pang17,
I have heard of this problem many times and it is usually due to overheating and motherboard problem. But first thing that you need to check is if the fan is working properly or not. You can use a canned air to blow out dust and accumulated particles from the fan.
However, freezing may also be caused by faulty processor. The unit may freeze (and overheat) while booting up, while using the computer or before the operating system loads if the processor is failing. To verify if the processor is failing, just access the BIOS (Basic Input/Output System) setup and test if it will overheat from there. If it does, surely the processor and/or motherboard needs to be replaced.
Hope this helps.
Jun 10, 2011 | HP Mini 1000 Netbook
What is the best solution for em350 hang up?
Usually when a laptop is freezing it is due to over-heating or operating system problems.
To help with over heating you can:
- Remove the bottom panels from your laptop and used compressed air to clean / free the fans.
- Get a laptop stand that does not obstruct the in-take / out-take for the air flow.
- Some people recommend laptop cooling pads.
Please let me know if this helps.
Regards,
KYTechnology
Mar 04, 2011 | Acer eMachines 350-2074 Netbook
I have a toshiba satellite p305d-s8828 laptop and have 19dc @ plug going into main board and 19dc on motherboard. Is the motherboard fired? And no power on computer.
Since you have measured the voltage on the motherboard I must presume you are saying there is no power "indicator light" on computer. If this is not the case please clarify. If the light is absent please test the battery as these laptops are not designed to work without a battery or with a dead battery. Operating without a battery can spike the motherboard or other components and cause failure due to overvoltage. If you do have a power indicator light then next observe whether the bootup is proceeding with a beep after the POST (power on self test) and whether you can hear the movement of the hard disk drive... possibly indicating failed LCD display or display drivers/setup. Press F8 after the POST beep to get to safe mode display drivers.
Oct 07, 2009 | Toshiba Satellite P305D-S8828 Notebook PC
Toshiba Satellite M35X-S329 freezing problems...
I have never heard of anyone being able to fix a bad motherboard other than to solder on a new DC jack which is not what your problem is. You should call Toshiba and ask them if this is a known issue and maybe they will fix it if there is an extended warranty.
Jul 13, 2009 | Toshiba Satellite M30 M35 Series 15.4 WXGA...
Computer freezes
make sure your CPU fan is functioning correctly, this happens generally when the CPU is overheating due to fan problems or stoppage. If the fan is ok, and the CPU is not overheating, try a different memory, one of will work.
helpful ? if not reply and i'll give you other hints
Mar 23, 2009 | Matsonic MS9327E (MS9327E+(USB))...
HP dv1000 Laptop Locks Up
It maybe bad sectors on hd but first Id defrag disk see if any improvement
Jan 23, 2009 | HP Pavilion dv1000 Notebook
R31 freezes up
Your computer shut down due a bad battery, Need to replaced.
Replace the battery first and see if your computer still freezing.
The reason(s) you may experience computer freezes, could be software related or hardware related; perhaps it's a combination of both.
Below is a broad list of some of common causes of computer freezes.
  • Memory
  • Video
  • Device Drivers
  • Bad Motherboard
  • Bad Devices
  • System Resources
  • Software
Sep 25, 2008 | IBM ThinkPad R31 2657 Notebook
Outside compresor freezing up and i don't here the ac come on inside the house
If the inside blower is not coming on the evap coil will freeze up due to no air movement. Could be a bad relay, motor or timer board.you need to get it check or it could cost you a compressor, $$$$
Jul 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Screen shakes and it freezes
i suspect a possible loose contact between the ribbon connecting the motherboard module to the LCD display module. if you can open up the laptop, check if the both the ends are snug and tight.
Mar 19, 2008 | IBM ThinkPad T42 Notebook
IBM ThinkPad T40 2373 Notebook Logo
108 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
