Question about Craftsman Garden
The engine runs for less than 2 mins and shuts off
The engine runs for less than 2 mins. as soon as it starts to warm up it shuts off and will not start again until it sits for a while.
  • 22 Answers
Could be oil low cut off , dirty air filter ,check fuel filter.
Posted on Oct 09, 2009
I have a 92 s10 blazer won't stay running I have replaced plugs wires distributor capcomputer moduleand nothing helped as soon as it warms up just a little bit it will start spitting and then die help...
Check the throttle position sensor. The fuel injector used for the choke is the only thing keeping the engine running. As soon as the engine warms up, the computer shuts off the injector causing the engine to starve.
Jul 18, 2014 | Cars & Trucks
Engine start to faill as soon get warm
have your distributor tested - might be getting hot and fail. Just like an external coil.
Mar 23, 2014 | 1996 Nissan Quest
Fix vapor lock
Hi, This sounds like the fuel pump needs replacing. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 24, 2017 | Ford Crown Victoria Cars & Trucks
98 honda runs fine then turns off while running on freeway then will crank but not start for about 30 mins changed ignition switch plugs an wires help plz
it may take some talking back and forth but i can help you fix this. does it seem like the engine stalls once its good and warmed up and wont start till its cooled down a bit? this is very common and its ussually caused by the coolant temp sender (not the one for the dash the one that runs you fuel and emissions) more or less it goes out and you car doesnt know its warmed up so it floods the motor out after a few miles because more or less the choke is stuck "on" . once the motor cools down it will typically start right back and and then repeat the symptom. ive seen other issues cause this but the coolant temp sender is very common and also a cheap fix ( just did one on a buick and the part cost 14 bucks and it took me about 15 minutes to replace). is the check engine or service engine soon light on or does it come on then go off?
Feb 18, 2012 | Chevrolet Camaro Cars & Trucks
Dewalt Pressure washer keeps shutting off for no reason. plenty of gas and oil, water running to it. starts fine and as soon as I start spraying it shuts down.
Had a similar issue with my dewalt 4200 pw. Unit starting shutting off after spraying for about 5 min. Then difficult to restart, but would start again eventually only to shut down a few min later. Had new engine oil, new pump oil, good gas. I changed the spark plug and unit runs great again!
Aug 08, 2010 | Dewalt 3800 PSI Pressure Washer
When driving my 96 jeep cherokee will shut down and it takes several mins for it to start back then it will do the same thing again what can it be
crank shaft sensor, as soon as car warms up, it will skip (engine stutter(, then when engine cools, so does crank shaft sensor. Good Luck
May 20, 2010 | 1996 Jeep Grand Cherokee
Engine starts easily and then stalls, is hard to restart
If the engine dies shortly after start. Squeeze the spray wand trigger to release pressure on the unit. When restarting let the engine run for a few min(2-3 no more) to warm up, the unloader valve on the pump should keep pressure to a minimum. If the engine stalls or will not run you need to check your carburetor and clean it. BECAREFUL as FUEL is FLAMMABLE and there are small parts in the carb float bowl that like to get lost. A rebuild kit for most carbs is less than $8USD and a can of spray carb cleaner about$2-3. Install a fuel cut off valve($6) to keep the carb from gumming up again. Shut off the fuel when not in use or for periods of prolonged storage. Take a picture of the carb on the engine(my memory is bad) and during disassembly to assure you get it back together properly. The idle screw should be turned in(to the right)till it seats lightly then backed out 1&1/2 to 2&1/2 turns to start with. After starting the engine adjust for good idle and running buy turning in or out to attain the best idle. If this is helpful, Please leave Feedback. Thanks, SnugglePants
Oct 21, 2009 | Coleman Garden
Garden Logo
110 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
