Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I've had my Maxtor external hard... Answer I've had my Maxtor external hard drive for a good 3-4 years, and for some reason, it just seems to stay idle and not let me access my data that is on it. The power source is plugged in and the "Green Light" indicator is on, but is not the bright green that it used to be. Even when trying it on different computers, it still doesn't let me access the info, nor does it appear as another drive on the computer.
  • 3,153 Answers
You may want to move the drive to a new enclosure or get the power supply checked.
removing the drive and connecting it to a suitable PC would tell you right away if it was the drive or the enclosure that was at fault.
Posted on Oct 06, 2009
    Novelist:
  • 171 Answers
You did well to have it work so long!
It is out of warranty - open it up, remove the drive from the case. It may be a SATA drive, but probably an IDE from 4 years ago...
Just place it in your computer and it should work fine. The most common problem is the controller card for the external connection has failed. so putting it in your computer as a normal drive will either fix it - or tell you that the drive has died.
Posted on Oct 05, 2009
Maxtor diamondmax plus 9 hard drive not seen by computer
I'd say you did a good job troubleshooting. Replace the drive.
Dec 29, 2012 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Hi there we purchased a maxtor basics 500gb hard drive about 3 years ago. we have had children in that time and unfortunetly our two year old daughter dropped it. we have taken it to a service store but...
If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
Mar 29, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Problem open up my maxtor one touch 500gb to retieve photos
first, recover your files. You will need to use hard drive deleted photo recovery program like Asoftech Photo Recovery, you can follow this video to recover deleted photo
http://www.youtube.com/watch?v=sNxApz_PBW8
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
Sep 09, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Maxtor blocks computer from processing - locks up
disable maxtor before shutting down the PC to narrow down the problem.
Jul 05, 2009 | Computers & Internet
Maxtor OneTouch 4 500GB External USB 2.0 and cannot access it. My computer does show only icon with now information
It is a bit boring and I do not know why it should be but for some reason your computer and new hard drive do not strike it off initially, just like other new-comer situations. Just keep on trying.
With your computer on, plug in external drive and switch on, it should then give a signal to your computer that a new device has been added. This provided that you are running ';Windows millennium, xp later DOS.
It seems to me that The Maxtor Being a "removable device" needs to be unplugged and plugged in again whenever you restart your computer, Perhaps this is what is happening, However as in my case I continued to do this until until the my computer got to rely on the new hard drive so much it could not run without it.
Good luck
Goffa
Jul 24, 2008 | Maxtor OneTouch II external hard drive...
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Old Maxtor/New Maxtor
If files you are trying to restore are encrypted you will have to use same software to retrieve them.. If not, any file in the external hard drive should be viewable with your windows explorer.
And U do not need drivers for external hard drives. They just plug into your usb port and work with modern OS after the unit is recognized.
Apr 15, 2017 | Maxtor OneTouch II external hard drive...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
151 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
