Question about Garden
UNIT TIPPED OVER IN TRUCK OIL IN CYLINDER PULLED PLUG AND REPLACED PLUG NOW WONT START
  • 3 Answers
SOURCE: wont start. no fire from the coil.
check the pick up in the Distributor
Posted on Mar 01, 2009
chryslertech
  • 115 Answers
SOURCE: truck wont start
Check your crank sensor, it bolts to the block on right rear and goes down into the trans bellhousing . You might have got the wire pinched between the trans and the engine.
Posted on Apr 05, 2009
  • 61 Answers
SOURCE: Truck accelerates sluggishly, then at cruising
over loading,,ck temp sencers to see if they are reading correctly, if temp sencers are reading cold after truck has warmed up,there telling the ecm to richen the fuel,,
Posted on Dec 13, 2009
  • 180 Answers
SOURCE: 1999 chevy truck diesel wont start
is it a 6.5? if so change your i.d.m aka injector drive modual located on the side of the injection pump!
Posted on Mar 19, 2010
SOURCE: is ther a kill switch
check the compression i work at btn powersports if you dont have enough compression it will not start if that dont work check the timing and if that dosent work, the valves might need to be adjusted or replaced. steve.
Posted on Oct 27, 2010
Have a brand new snapper push mower used once now it won't stay running when set down flat to start cutting what's wrong with it
what do you mean set down flat? it should always be set flat. if you had it tipped over or standing on end that's why it wont run. take out the spark plug and try to start it a few times. with the plug out it wont start you just want to blow out any oil or gas that may have got in the cylinder. put a new spark plug in it. it should run now.
May 08, 2016 | Snapper Garden
U tube chainsaw pull cord wont pull start
Some saws with autotmatic oiling will leak bar oil into the cylinder and cause this. Pull out the spark plug and hold the saw so the oil runs out of the spark plug hole. Pull the starter cord till no more oil sprays out of the hole.Clean the oil off the plug and start your saw. It will smoke more than normal till the extra oil is burned out.
Sep 05, 2014 | Homelite Garden
Homelite power washer too much oil
Hi Martin, check the level of the oil in the engine, if the level is low, the machine has been tipped on the side and the oil has gone over the head. Make shore that engine is on the flat ground when used or transported. Tilting the unit over 20 degrees will cause the oil to go over the head. Two ways to fix the problem pour some petrol in the cylinder, put a rag on the spark plug hole and pull the starter rope few times to clean the cylinder, repeat the same until the cylinder is clean. You have to check the carbi for oil getting into it, and clean it. Make sure you clean all the petrol before attempting to start the engine. It is a bit messy but not require to pull the engine apart. The other way to clean the oil is to remove the cylinder head off and clean it, its the proper way of doing the job, but requires a lot of dismantling. Hope this helps. Cheers
May 19, 2014 | Honda Pressure Washer PSI 3000
Pressure washer hard to pull string
Unless your unit is equipped with an easy start feature...and I think these are not, it is not usual to have to pull the trigger on the water gun to start one of these units. Also...if there is any chance that the washer has tipped over, there is a possibility that oil has gotten into the engine cylinder. Oil will not compress and the rope cannot be pulled..at all. Remove the spark plug and step back away from the exposed hole. Pull the recoil handle and watch for spraying oil from the spark plug hole. Pull a few more times, clean up the plug and the unit may start. If not, you may have to remove the carb bowl and drain more oil. Check your oil fill level. If your gas level is suddenly low you may have gas in the oil crankcase and need to change your oil. When the washer starts it may blow smoke for some time before it clears up.
Oct 20, 2012 | Karcher 2500 PSI Pressure Washer
My edger tipped over briefly, now the starter cord is hard to pull and it won't start.
Try removing the spark plug and squirting some carb cleaner or starting fluid in the cylinder. Pull the starter cord several times for the piston to drive out the oil. Clean the plug and replace it. Try to start as normal. If you have starting fluid squirt a shot in the air cleaner to help make it easier to start the first time.
Nov 25, 2011 | Mtd 25B-520D200 CA Gas Lawn Edger
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
Tractor was tipped and will not start
Depending on which way the mower tipped over and how long it stayed that way there are a couple things you should check. First, the oil in the crank case. Many times when engines are on their side, gas can freely flow from the carburetor into the cylinder and down into the crank case. If this happened the oil level will be very high and the oil will be thinned out. A simple oil change will take care of this. Remove the spark plug and check the cylinder for gas or oil. With the engine on its side either gas from the carburetor or oil from the crankcase can fill the cylinder above the piston and make it hard for the engine to start. With the plug out, run the starter several seconds to clear the cylinder out. If oil is the problem, squirt some gas in the plug hole to thin out the oil so it will come out the plug hole when you run the starter. Replace the plug, check the oil level and try to start the motor. It may take several tries and the motor may smoke a lot when it starts. This is OK as it has to burn out anything in the cylinder to get back to normal.
Apr 27, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower was tipped upside down and now won't start
First check to see if you have enough oil. If you do does the engine smoke? If it does, continue to start and let it run until it stops. If the time it runs keeps extending, keep doing it. You are trying to burn out the oil that leaked in to the cylinder when it tipped. If that doesnt work, write..Good Luck...Lee
Sep 28, 2009 | Garden
1994 dodge 1500 wont start after changed plug wires
Make sure your firing order is correct. Also if you replaced cap and rotor make sure coil wire isnt loose. If you cant find the firing order its stamped on your intake manifold, cylinder numbers should also be stamped above each cylinder on the manifold.
Mar 27, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Wont Start
Have another look at your plug wires, and make sure that you have them in the right order. As you probably know, if the firing order is wrong, you can have problems. That is somewhere for you to start, anyway.
Jun 18, 2008 | 1988 Mazda B2200
Garden Logo
85 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
