Question about Philips Televison & Video
Need to know what parts to fix it
My tv will turn on but the screen is black, what parts do i need to fix it?
  • 647 Answers
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour. Be sure to vote/rate me if this helped Thanks!
Posted on Oct 05, 2009
How do I fix a flat screen tv that when turned on the screen is black with no picture?
place a turned on torch against the tv screen while tv on can you see a picture ? If yes then back light problem possibly inverter that powers the back light.
You tubesearch on tv faults for more insight on possible causes of black screen or no screen on Tv's
if no picture with torch then it might be main board .
Check you tube for ideas on possible causes.
Jan 27, 2017 | Televison & Video
Samsung flat panel TV. I have sound with a black screen. Can you help me
Hi Cherie, The link below is a YouTube video showing how to fix a Samsung television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS.. Samsung UN46D6000 No picture Sound OK problem FIXED BN95 00497B BN41 01662A
May 01, 2016 | Samsung Televison & Video
I have a Philips Ambilight 47PFL7603D/10, during use the screen will randomly turn off/go black, but the sound remains as normal. If I turn the TV off and on again the TV will work again for 5-10mins.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
ayo
Aug 02, 2015 | Philips Televison & Video
Samsung hp-r4262 black screen
your y main or x main is dead or y buffer board
Dec 15, 2011 | Samsung HP-R4262 42 in. Plasma Television
All of a sudden teh screen goes black when I unplug and plug it back it works for a while and then it happens again
You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections.
The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad.
This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
Black Screen - Sometimes, the TV may display a black screen, now you need to check the cables whether they are properly plugged or not. Reconnecting all the cables can also work for this problem. Also, if the screen has a screen saver, check how it's set up. And, if nothing works for this issue, then there is a possibility that the lamp, rear projection, or the LCD panel may have been damaged. Now, you need to check your warranty card of your television and se your set comes under the manufacturer's warranty period. Call the customer service for technical problem and get replaced if a part demands it.
Jul 08, 2011 | Proscan 42LA45H 42 in. LCD TV
JVC Model no: AV-48WP34 Projection Problems
OK, problem seems in convergence section of TV and can be confirmed by testing voltage supply as mentioned in schematics.
You can download service manual copy from Manual Zone for small fee and it has schematics, exploded views. board location, part numbers info.
Let me know if you need further help.
Thanks.
May 07, 2009 | JVC Televison & Video
Black screen with a horizontal white line across the middle.
You would need to replace the flyback on this and your looking aroung $65 parts and $85 labor to shore this problem up. We can recommend you a repair shop or you can purchase a new TV its all up to you
Rulds2008
May 02, 2009 | Sanyo DS24205 24" TV
Syntax olevia lt32hv 32 inch lcd tv. power surge now no picture
The electronics are known to go bad with these TV's, and I'm looking to buy someone's junk TV that has a good screen, rather than have to throw it out.
(So if anyone is out there with a 532-B12 that isn't working, send me a message!)
Yours might be worth fixing - however I know sadly that parts are nearly impossible to get for these TV's, and the manufacturer is virtually impossible to contact.
If you DO manage to contact anyone (manufacturer or otherwise) who can source or supply parts, PLEASE do let me know - it's been nearly impossible for me, and I want to replace my cracked screen in my TV.
If you can't, please let me know - I'll gladly give you a few bucks at least to salvage the screen from your TV, to transplant into mine, rather than turning it into junk on your curb.
Jan 07, 2009 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Televison & Video Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
