Question about Brother MFC 210C All-In-One InkJet Printer
Will not accept new yellow ink cartridge.
I have taken the new cartridge in and out many times and yet I still get the message "no cartridge, open scanner cover then reinstall ink cartridge"
  • 10 more comments
  • dixey Dec 26, 2007
    Yes I did use Brother Cartridges.
  • PeggyD Dec 30, 2007
    I installed a brand new Brothers ink cartridge and get the message - no cartridge - remove and reinstall
  • Anonymous Jan 06, 2008
    i have the exact same problem except it's my black ink cartridge
    PLEASE HELP ME!!!
  • K1J2T3 Jan 10, 2008
    hi,
    YES i have the same PROBLEM!
  • Betsy13 Jan 17, 2008
    Yes, even upon installing original brother ink and following all the directions on their website (turning off for 10 sec., etc.) It still says there is no cartridge. Could it be the slot is broken? The other ones work fine...
  • elegantlady Jan 21, 2008
    hi I have the same problem , very stressing
  • Anonymous Jun 16, 2008
    The printer will not register that the cartridge is in place and will not print anything because it wants a cartridge. I tried to push the metal piece up more so the cartridge makes more contact but it didn't help.
  • Maizy46 Nov 02, 2008
    I have changed all my ink cartridges several times and still get the message that they are empty or near empty.
  • Varughese Varughese Dec 07, 2008
    Ink Cartridge Problem The followingink cartridge (s ) appear to be missing or damaged Refer to printer documentation
  • mattjuge Feb 17, 2009
    same old story the others have told
  • Anonymous Mar 01, 2009
    my mfc-210c all in one won't except any of my new in cartridges.
  • kosmo_gypsy Mar 04, 2009
    Mine is doing the same thing. I have tried everything suggested here with no luck.
    Also, how can I use the other functions of my machine? Without ink, I can't print, but I still should be able to scan to my computer. It won't work!
I replaced all the ink cartridges and everything worked fine after
Posted on Jan 17, 2008
  • 832 Answers
Do you use generic carts?
If yes try another cart (always best: original brother carts)
http://welcome.solutions.brother.com/bsc/public/us/ca/en/faq/faq_list.html?reg=us&c=ca&lang=en&prod=mfc210c_all&Cat=11
Posted on Dec 23, 2007
  • Mix-it-up
    Mix-it-up Dec 26, 2007
    Did you follow the link given above?
  • Mix-it-up
    Mix-it-up Jan 17, 2008
    Open cover. Take all carts out. Close cover. Open cover. Display should give the order to place cart in. If not, place in cart and take it out again. Answer questions if you have replaced the carts. Do make a firmware update (see brother homepage of your country).
Still doesn't work i did it 3 times still read install cyan
Posted on Jan 21, 2008
    still not working
How to change ink cartridge in epson nx215
1. Turn on your Epson printer. 2. If a cartridge is expended, you see a message on the printer's LCD display screen. The icon on the screen indicates which color to replace. Press ink.13.7.1.jpg Start (NX210 Series) or OK (NX410 Series). If you're replacing a cartridge before you see a message on the printer's LCD display screen, do one of the following: NX210 Series: Hold down the Scan button as you press the Index Sheet button, then release the buttons. Press ink.13.7.2.jpg or ink.13.7.3.jpg to select Ink Cartridge Replacement, then press ink.13.7.4.jpg Start. NX410 Series: Press Setup, press ink.13.7.5.jpg or ink.13.7.6.jpg to select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 3. Open the scanner. Note:
Your printer model may vary from the ones shown in this section, but the procedures are the same. ink.13.7.7.jpg Note:
Do not touch the white cable inside your printer.
Do not open the ink cartridge cover while the print head is moving. ink.13.7.8.jpg 4. Open the cartridge cover. ink.13.7.9.jpg 5. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. ink.13.7.10.jpg Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 6. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) ink.13.7.11.jpg 7. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. ink.13.7.12.jpg 8. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. ink.13.7.13.jpg 9. Insert the new cartridge into the holder and push it down until it clicks into place. ink.13.7.14.jpg 10. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. ink.13.7.15.jpg 11. Lower the scanner. ink.13.7.16.jpg 12. Press ink.13.7.17.jpg Start (NX210 Series) or OK (NX410 Series) to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. If you continue to see an ink replacement message on the LCD display screen, Press ink.13.7.18.jpg Start (NX210 Series) or OK (NX410 Series) and press down all the cartridges securely. Then press ink.13.7.19.jpg Start (NX210 Series) or OK (NX410 Series) again. Note:
If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. Caution:
Never turn off your Epson printer while ink is charging or you'll waste ink.
(Taken from the Epson online manual available here)
Oct 16, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Yellow ink will not show on test page. It is full. New
Open it up and look at the yellow ink cartridge. Make sure all of the packaging is taken off, since it is new. Put it back in and give it a shot. Sometimes just reseating the cartridge can help.
Mar 05, 2011 | Epson WorkForce 600 All-In-One InkJet...
Replaced the yellow ink cartridge with a new one and message still appears on screen that the yellow cartridge needs replacing. Appears that the printer does not "see" this new cartridge. I...
This sounds like the chip on the cartridge is defective. Try a different cartridridge. Take the failing cartridge back to the vendor for a replacement or refund.
Your description for corrective actions taken are in-line with accepted procedures.
Let me know if you have any other questions. Thanks.
Jan 18, 2011 | HP Officejet 6500 Wireless All-in-One...
How do I remove the black ink cartridge to put in a new one?
1 Remove and Install Cartridges Be sure you have your replacement cartridges handy before you begin. You must install new cartridges immediately after removing the old ones. Caution:
Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. 1. Turn on the Epson Stylus CX8400 Series. If a cartridge is low or expended, you see a message on the Epson Stylus CX8400 Series LCD display screen. If a cartridge is expended, you must replace it to be able to print. If a cartridge is low, you can continue printing until the cartridge needs replacement. If you're replacing a cartridge before you see a message on the Epson Stylus CX8400 Series LCD display screen, press Setup, select Maintenance, and press OK. Then select Change Ink Cartridge and press OK. 2. Open the scanner. 3. Open the cartridge cover. 4. Squeeze the tab on the cartridge and lift the cartridge straight up to remove it. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning:
If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children. 5. Before opening the new cartridge package, shake it four or five times. (Do not shake a cartridge after opening the package; ink may leak.) 6. Remove the cartridge from the package, but be careful not to touch the green chip on the cartridge. 7. Remove the yellow tape from the bottom of the cartridge. Caution:
Do not remove any other labels or seals, or ink will leak. 8. Insert the new cartridge into the holder and push it down until it clicks into place. 9. Once you replace all the necessary cartridges, close the cartridge cover and push it down until it clicks into place. 10. Close the scanner. 11. Press OK to begin charging the ink. This takes about 2 minutes. When you see a completion message on the LCD display screen, ink charging is finished. Caution:
Never turn off the Epson Stylus CX8400 Series while ink is charging or you'll waste ink.
If you see an ink replacement message on the LCD display screen, press OK and press down all the cartridges securely.
Nov 24, 2010 | Epson CX8400 All-In-One InkJet Printer
My yellow ink ran out and I finally replaced all inks this evening. Now, with all new inks, I keep getting a message that the yellow needs to be replaced. Any suggestions? I've turned off the printer,...
I had the same problem with mine but I bought a refill cartridge instead of a new one and went through three refilled cartridges when I found that it was that I needed a brand new one. For some reason, the HP printers and some other printers need to know that you are using the same brand of ink as the printer. if it is another brand it wont except it and it wont let you print anything! So make sure it is a brand new hp brand ;)
Nov 12, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
PRINTER WON'T ACCEPT NEW INK CARTRIDGE
From the Brother solutions website:
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridges, then one or more of the cartridges may not be properly installed. Verify that the cartridges are installed correctly by following these steps:
Note
    Cartridges that have already been installed are no longer vacuum-sealed, so it is very important that these cartridges remain upright. If a cartridge is removed from the machine and placed on its side, air may be introduced into the ink supply tubes. As a result, repeated cleaning will likely be required before normal print quality is restored.
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    If the date and time appear on the display, the issue is resolved. If the display continues to show NO CARTRIDGE, continues to Step 2.
  2. Open the scanner cover by lifting it from the right-hand side until it locks securely into the open position.
  3. Remove the black ink cartridge by pulling the white plastic hook (locked over the edge of the ink cartridge) toward you, then lifting the cartridge out.
  4. The LCD should prompt you to install the black ink cartridge.
  5. Reinstall the black cartridge. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge. Repeat STEPS 2 - 4 to verify each that of the color cartridges (magenta, cyan and yellow) is installed properly, then continue to STEP.
  6. Close the scanner cover. The unit should begin cleaning automatically.
Dec 09, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
159 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
