Question about Black & Decker BL1900R Blender
I need the black screw on part that goes onto the glass jar. Where can I order it?
I also am looking for an answer to this question.
Posted on Dec 29, 2009
How do you mount up a blender?
The rubber ring goes between the jar and the blade assy housing. It never goes under the blade assy, always to the jar.
Jun 01, 2014 | KitchenAid 5-speed Blender With Glass...
Blender glass jar is leaking at base
It will either be the rubber gasket (it goes between the glass jar and the blade assy) or it could be a worn bearing/bush around the chopping blade shaft. Replace either the gasket or the blade assy.
Apr 02, 2014 | KitchenAid 5-speed Blender With Glass...
Starbucks Glass jar replacement for blender
I bought an Oster 6 cup glass and it works perfectly on the Starbucks Barista blender. It has to be the 6 cup NOT the 5 cup or the blade mechanism won't fit. the 6 cup screws right on your old blade base and it was $10 new on Ebay including free shipping.
Feb 20, 2014 | Braun MX2050 Blender Powermax Replacement...
I need a part for my Black & Decker Model BL2020R.
Perhaps you could find Black & Decker parts web-site for your blender model BL2020R. It will show a parts diagram for your machine. Find the part and order it online.
Dec 24, 2012 | Applica Black & Decker Blender With Glass...
Hello, I didn't see model #BBL600XL which is what
The jar has to be on for it to blend.
If you replace the jar first check the printing on your old jar. If your jar has blue print you will need a new jar and blade, Breville redesigned the jar and now the old blades don't work with the new jars. You tell the difference between the jars by the print color, old is blue, new is white.
BBL600XL/06A jar part number
BBL600XL/14A blade part number
Contact Breville at 1-866-273-8455 for service center locations.
Mar 23, 2011 | Breville BBL550XL 5-Speed Blender
Parts need Black plastic ring for glass jar
This is what I could find, Contact info for the company, they don't have parts listed on their site but you should be able to call them and order. They are based out of Canada.
Toll free: 1-800-421-1223
International: 1-203-922-7902
You may also submit an order by fax to 704-987-8389.
Hours: 8:00am - 8:00pm EST
Monday - Friday
May 05, 2009 | Toastess TB-50GS Single-Speed Blender
Plastic pieces on glass jar and base are worn out and shaved down
I did the same thing. Order parts at thegourmetdepotco.com -- This problem is caused when you put the rubber gasket underneath the blade instead of above it. This causes two problems: 1. It lifts the teeth on the jar away from the teeth on the drive gear, which can grind down and break off the teeth, and 2. If the drive gear contacts the rubber gasket, it will melt the rim of the drive gear. In the future, to reassemble the jar after cleaning, first put the rubber gasket on the jar, then the blade, lastly screw on the base ring.
Apr 19, 2009 | Margaritaville Frozen Concoction (DM1000)...
Need Jar
purchase from any of the below links>>
http://buyitnow64.stores.yahoo.net/habeplbljar.html
http://cgi.ebay.com/KENMORE-BLENDER-GLASS-JAR-WHITE--BQ_W0QQitemZ250368347086QQcmdZViewItem
http://cgi.ebay.com/KENMORE-BLENDER-GLASS-JAR-BLACK-BQ_W0QQitemZ280310226122QQcmdZViewItem
please rate this solution.
Thanks for using FixYa.
Feb 09, 2009 | Kenmore KMB048 Work Top Blender
Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Feb 23, 2008 | Blenders
Replacement parts
My blade assembly leaks just as you are describing. I found a website that offers replacement parts for Black and Decker appliances:
[Note: I have not ordered from this site yet so I can't say how reputable they are.]
They offer the glass jar, blade assembly, and other parts for the BL1900R. Judging from reviews, it may not be long until something else goes wrong.. I am gong to order the replacement part this one time. If anything else goes wrong though, forget it. Too bad. Black and Decker usually makes good stuff.
Jan 04, 2008 | Black & Decker BL1900R Blender
Black & Decker BL1900R Blender Logo
112 people viewed this question
Top Black & Decker Blenders Experts
john h
Are you a Black & Decker Blender Expert? Answer questions, earn points and help others
