Question about Kenmore Dishwashers
Model # 665.16032401 Kenmore untrl wash Clean light keeps flashing won't reset
  • 4 Answers
SOURCE: Kenmore Dishwasher model # 665
replace control board
Posted on Feb 16, 2008
SOURCE: My kenmore ultra wash model
my model #665 dishwasher will not pump water into the unit
Posted on Jul 15, 2008
  • 188 Answers
SOURCE: Kenmore dishwasher, model 665.170 344 01. "Clean" light keeps flashing and will not stop. Have tried everything in the manual and the light still will not stop flashing.
If the clean light flashes 7 times, pauses then repeats...
If the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive).
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Feb 20, 2009
  • 188 Answers
SOURCE: Clean Light is flashing
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
Posted on Mar 02, 2009
SOURCE: Kenmore 665 dishwasher blinking clean light
you'll need to enter a diagnostic mode, press in this order, hi-temp(sani-rinse)----heated dry--hitemp---heated dry... all lights should light, close door and let cycle for about a min, after press the cancelbutton, you should be good to go, the buttons on your model may read slighty different names, if this "toggle of buttons" does not work, you can remove thelower access panel and htere willl be a tech sheet/trouble shoooter behind the panel, in there it will explain how to enter diag/test mode
Posted on Jul 02, 2009
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
"Clean" light keeps flashing. Machine doesn't
Hello & Welcome to FixYa
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Kenmore Dishwashers
My Kenmore Ultra wash dishwasher will not cycle.....the green clean light keeps flashing. How do I reset the cycle?
Kevin
Apr 11, 2011 | Kenmore Dishwashers
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The clean light keeps flashing, and we cant cancel the program or get it to wash
Kevin
Dec 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light is flashing machine won't start
Kevin
Dec 09, 2010 | Kenmore Dishwashers
Clean light keeps flashing, cant get it to reset. What can I do?
Hi, if the clean light flashes it is indicating the was no rise in water temperature during the water heating cycle. This link below will explain things that could cause it and tell you how to reset the control so you can wash for now. Let me know if you have questions.
Be sure to follow the 'key dance' just as specified'
Thanks!
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
May 02, 2010 | Kenmore 24 in. 17022 Built-in Dishwasher
The clean light in my Kenmore dishwasher keeps
It has to do with the water temperture, either the water entering the dishwasher is too cold and the heater can't get it up to temp, or the heater unit has problems... Push the Air dry ,then the sani wash buttons a few times and all the lights will light, it resets the computer .
Nov 02, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
-high temp wash
-heated dry
-high temp wash
-heated dry
Jul 18, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
177 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
