Question about Makita Drills
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
    Sergeant:
  • 302 Answers
Have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Posted on Oct 06, 2009
Problem taking batteries out of older Makita drill (6095D) to recharge/replace them.
there is a clamp on the bottom that has to be unlatched and the battery should just pull out of the bottom, unless it is stuck by corrosion and then you might have to "TAP" gently to remove. You can download a breakdown of this tool at makitausa.com to see what I am talking about.
Jun 26, 2011 | Makita Drills
How do you remove the clutch on a makita 8406 have split the body so far ..thanks
How is the clutch removed from the makita 8406 core drill
May 15, 2011 | Makita Drills
Charger for makita 9.6volt 6095d not working
revisar las terminales del cargador que hasen contacto con las del taladro yestas tambien porque puede ser que esten oxidadas y linpiarlas con limpia contactos y con lija n400 o mas fina
Oct 05, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do you remove chuck?
open the jaws-remove any bit and look down inside-you'll see either a hex or phillips head screw. It will likely be left hand threads so be careful. It should come right off but you might need to lightly pry it off.
Jun 14, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
What is the procedure for removing the chuck from a makita 6095D 9.6v drill?
Most chucks use a tapered shank that allows you to remove it with a good tap on the bottom. Other chucks have slots in the slots in the shaft that allows you to tao it off with a wedge type key. You could always use a dent puller and chusk on the screw.
Good luck, Jack
Aug 21, 2009 | Drills
I can't unscrew the bit?
just above the operating button there should be a lever that pushes left to right.
Jun 16, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
How to replace forward and reverse switch on a Makita model 6095d cordless drilldriver
If you are mechanically inclined you should have no problems but if not this is involved. First I would recommend going to the Makitatools.com website and on the right side type in your model number and look at a breakdown for this unit. To start with you have to remove the chuck, then the collar with the 2 springs under it and then remove all screws from the housing separating it carefully so none of the parts jump out. The switch is polarity sensitive so make sure of the wiring. If you still want to tackle this let me know and I will go into more detail on this. Good luck
Apr 08, 2009 | Makita Drills
Drills Logo
821 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
