The best way to prime the pump hoping that you havent ran the engine to long without oil pressure
is to remove the oil gauge switch ORoil light switch on the engine and get a connector with the correct thread to screw into the block and fit a hose to it and to a 1/2 ltr oil can pump oil in as hard as poss and then turn engine over IN REVERSE(Backwards) 3 times and then (pumping every time) refitswitch and start it should be ok....
