Question about GPS
Hi I have a navman s100 the charging socket has broken/come loose and I need to take the bottom panel out so I can have a look at it I have taken the two screws out but the panel wont move does the back have to unclip as well if so how? Cheers, Andrew.
  • 1 more comment
  • andrew46 Oct 05, 2009
    yes I would like to proceed
  • andrew46 Oct 06, 2009
    Hi that video is for a different product I have the navman s100
    President:
  • 1,714 Answers
Yes, use a very thin blade and slide it between and gently pry it open.
Posted on Oct 07, 2009
  • 11,896 Answers
If you have any questions, feel free to ask. Please copy and paste this link in your address bar under a new tab to view a video on how to disassemble this gps unit:
www.youtube.com/watch?v=7O0ymDyY8Zg
Posted on Oct 06, 2009
  • 770 Answers
Unfortunately, this unit is easily damaged, especially if you happen to be using an aftermarket recharger. It is designed for repair to be done by qualified techs for navman, so the proceedure for entrance is closely guarded doable,, however, you would have to be highly versed in microscopic souldering skills, do you wish to proceed???
Posted on Oct 05, 2009
How do get map updates for navman s100
Go to the navman website download the latest version of the updater software (if its not done already) and check the maps section as it will automatically update as much as it can but you can always buy newer map versions with more features.
Oct 01, 2012 | Lexerd Navman S100 S150 S200 S300T TrueVue...
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
Hi my phone charger port on my Sanyo 2700 is loose and my phone won't charge. How do I get it fixed?
Follow this steps.
* Need to visit your nearest mobile spare parts shop.
* Take a brand new charger socket.
* Remove your mobile panel.
* Then remove the screws.
* There you can find your mobile board.
* At the bottom of your mobile you can find the charger port.
* Remove that full socket.
* Place there your new socket.
* Then try to charge it.
* After getting conformation you can fix your Panel.
Thanks for your question.Thanks for using fixya.
Jul 13, 2011 | Cell Phones
My Navman S100, Model N214, has a loose power connection at its base (one too many shoves into the glove compartment). I need to open it up to see if I can solder it, but after the 2 small screws, I'm...
To open the unit there are 4 screws, 2 are on the base. There are also 2 on the back at the top that are hidden by rubber plugs. Remove the plugs using a small flat screwdriver. Once the screws are all removed use a small screwdriver or butterknife to slide down the side and the back should pop off.
I have the same problem with mine, but the USB connector seems to go straight to a board, so don't know if can be tightened, soldered or otherwise repaired.
Apr 13, 2011 | Lexerd Navman S100 S150 S200 S300T TrueVue...
Pin inside my navman icn520 charging socket has broken off - where can I get a replacement socket
You can go to your local electronics store or you can get one of garmin's website.
Dec 12, 2009 | GPS
Hi the charging socket has broken/come loose and I need to take the bottom panel out so I can have a look at it I have taken the two screws out but the panel wont move does the back have to unclip as well...
Unless you are REALLY electronically inclined, there is very little you can do. If you were to get the camera apart, then determine the issue, you would have to be versed in microscopic soldering to make the repair, and that is if there were no other part required. Unfortunately, what you are attempting to repair requires HIGHLY skilled techs, that are familiar with your brand and model of camera. No easy fix for you unless you are very maticulious, and precise. Also, once disassembled, the problem would have to be obvious. Would not recommend this repair to a novice
Oct 05, 2009 | Cameras
I want to reset my navman s100 to its factory settings
Go to the setting area and select "Preferences" there is a "reset Factory default" option select it.
for more info...read the user manual--
http://www.navman.com/docs/manuals/navman-s-series-spirit-hardware-manual-en.pdf
Mar 19, 2009 | GPS
I suspect my charger socket on navman has a fault was intermitant now it wont charge at all, output from charging unit is ok output is 6v dc
Hi Rob here i solved prob thanks side contact was not making connection for recharging plug managed to manipulate it so it is making good connection now..
Regards Rob.
Jul 20, 2008 | Navman GPS
F20 power port connection broken in unit.
I have recently acquired a Navman F20 Satnav with a broken USB port (It was rattling around inside the unit.)
I took apart the case and re-fitted the USB port with no problems at all. Just with a steady hand and a fine tipped soldering iron. I also superglued the port in place to add extra strength.
Put it all back together, and it now charges and connects to the PC exactly as it should.
So, before you throw away a sat nav with this problem, contact me and I can fix it for you, or, alternatively I will offer to buy the broken unit from you.
My Email address is darren.lee27@ntlworld.com.
Thanks
Jun 22, 2008 | Navman F20 GPS Receiver
Navman repair
Any electronics repair place or perhaps a camera repair shop should be able to fix it for your. Search google or your local phone book for electronics repair or camera repair. This is a very easy repair IF you are electronics savvy, but not a good first/learning project. This will require either soldering a loose connector back to the board or they may need to find and purchase a new connector to replace the old one if it is broken.
Nov 09, 2007 | Navman ICN510 GPS Receiver
GPS Logo
66 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
