Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Mini-USB port has broken off from my 500 gb Seagate drive
Help! This is the exact problem that karaokemanhi reported today. Except my mini-USB port has completely fallen off and is now rattling around inside the base of the Seagate harddrive casing. I don't feel comfortable cracking open the casing, messing with hardware issues, but I feel this is a very simple issue that simply requires either a mini-USB port replacement or else a shell replacement for the hard drive. The computer repair people I have spoken with are suggesting I look into "data recovery" and replacing the hard drive entirely, and I am fairly convinced that type of solution is unnecessary for what appears to be a very simple hardware replacement issue.
Can anyone please advise? Also, I live in Seattle so if there is anyone in the online community that is local and could help me in person, please contact me! Thanks! Amy
    Novelist:
  • 171 Answers
If you have space in your computer - simply open the case fo the External drive - unscrew the HD from the case, disconnect the cable and place into your computer.
All problems solved and it will run faster too!
Posted on Oct 06, 2009
    Scholar:
  • 82 Answers
Yeah you can probably just get the enclosure dissassembled. googling " how to disassemble seagate freeagent pro" pulled up a few links but if you're not comfortable doing that, try asking for help from local college computer lab geeks. I'm on the other side of the country from you so, can't help you much. The usb port that fell off was probably connected to the drive via an adapter so likely the hard drive itself is not damaged. Data recovery is much more expensive and I agree it isn't reasonable for this kind of problem.
Posted on Oct 05, 2009
Connot connect my seagate 500 external drive to pc
I don't understand, the pc must have USB ports on the front and rear panels, but! if your pc is the older variety it will not support the eSATA drive systems.
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have seagate 500gb sata freeagent. usb port broken. need to buy the pcb connector because I dont think i could solder back the broken usb port to the board. anybody know where to order?
I believe you are looking for this: USB Mini-B (5-pin) you are looking for the "socket"
Here is a list of products to choose from:
https://www.alliedelec.com/search/searchresults.aspx?N=0&Ntt=USB+Mini+B&Ntk=Primary&i=0&sw=n
Please note; This will be extremely hard. most of those products have no pictures and you are not sure exactly what you are getting, luckily they are pretty cheap so i would recommend getting a couple that sound right.
Good luck, be careful.
Hope this Helps.
Mar 19, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The usb port is broken? how can i get to my info on the drive?
Open the enclosure.
Separate the disk-drive from the USB-to-disk-drive adapter.
Connect the disk-drive as a 'slave' disk-drive in some computer,
to access the files.
Or, for about $30, buy a new 'empty' enclosure, and transplant your disk-drie into that enclosure.
Oct 26, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Assembled Computer with Processor Intel Dual Core (R) @ 270 GHz, 3 GB of RAM equipped with Microsoft Windows XP Professional Edition version 2005 service Pack 3 with Wi-Fi Netgear 108 Mbps Lan...
yah you must buy a Y-USB cable for your external hardisk. this is connection both ends are one is for hardisk and the other two cable is for USB slot of computer. why it two wires connection to usb because one wire is for Data and the other is for Power. If doesn't work..it might be a problem in your Operating system. i recommend to you to reinstall your Windows OS.. theres a 4 reasons why it happen appear the error... deffective USB cable..corrupted driver of USB device for seagate, virus infected of your systems..and maybe your hardive is deffective. Please rate if this is HELPFUL..thanks
Aug 22, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I AM AMONG THE MOST DISORGANIZED PEOPLE IN THE WORLD! I NEED A SPECIFIC DESCRIPTION OR IMAGE OF A SEAGATE 500 GB FREEAGENT DESKTOP USB DRIVE POWER SUPPLY SO THAT I MAY DIFFERENTIATE IT FROM THE LITERALLY...
Hi a 500 GB ( Gigabyte) is an hard hard drive is could be for laptop or desktop so it depend on the computer you have.USB drive is a little device about three inches long and one inches wide it is use do store data by plugging it into the USB port on the computer. Power supply is the square device which supply the whole computer with power,it has many wires with connectors at the end of the wires,and most connectors has four pins except the one which connect to the motherboard,because it can have either 20 or 24 pins. If you have any questions please feel free to ask me
Jul 27, 2010 | Computers & Internet
The USB port on my seagate 500GB external drive has broken off, and is somewhere inside the case.
You should be able to pop open the enclosure to retrieve the hard drive. You may need to take out a few screws.
Once you've done that, you can purchase another external USB enclosure to replace the broken one.
Aug 09, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computer does not recognize mY SEAGATE BARRACUDA 7200. 11 500 GB
Try using your SEAGATE Hard Disk on another PC , if it works then you have one of these problems,
1. Your USB Port in your PC (Or Laptop) is broken and you have to get another one*
2. You have a software problem (Try reinstalling your OS or scan for viruses).
3. The USB Cable has a problem (get a new one).
(*) some technician can replace your USB port or fix it, or you can buy a "USB Hub"
Jan 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
1,113 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
