Question about Ovens
I cleaned my self clean ariston oven with an unsuitable cleaner & now it has rust marks on the sides of it, is there any way i can fix this?
  • 867 Answers
You could rub the rust marks off safely with vegetable oil on a rag
Posted on Oct 05, 2009
My self cleaning oven in the GE JD630sFSS does not clean splashes on the sides. That is not a good thing. What can I do about this?
There are some products out that can help with this problem. Check out Easy Off for a good one. But get the correct one some are not for self cleaning ovens. If the protective layer has come off an you see some rust from the steel sides it will never clean. You will need one of the can cleaning products to do the job.
Jul 18, 2017 | GE Ovens
How can I clean the pullout racks and side racks of self-cleaning oven?
The racks may have to be removed, if possible, and cleaned separately using oven cleaner.
Feb 18, 2016 | Ovens
Ariston tc720 dials have rubbed off
We had the same problem when our cleaner rubbed off the markings. Ariston "customer services" were very unhelpful (the model is now so old they don't offer any replacement facias for it) but managed to get replacement stickers from Mark at
http://www.ovenlettering.co.uk/. They come with a diagram for all four dials showing where they should go and are very easy to apply. Would highly recommend.
Jan 19, 2014 | Ariston Technologies Ariston FO98P...
I have a frigidaire self clean electric oven but I am not sure how to operate the self clean
lock the oven door lever to self clean side, and turn it on self clean - it should shut off automatically when cycle is complete.
BE CERTAIN NOTHING IS IN THE OVEN WHEN YOU TURN IT ON AS IT LOCKS SHUT!
ALSO CHECK TO BE SURE NO ONE USED CHIMERICAL CLEANER IN IT PRIOR -- DANGEROUS FUMES WOULD BE A RESULT
Best regards
Ck
Aug 18, 2011 | Frigidaire Ovens
How to clean oven model JSP46D P1BB
That model is self cleaning . So you have to remove the oven racks and press the button marked self clean. The self cleaning cycle will last anywhere from 2-4 hours . once the oven unlocks after the cycle is over you have to wipe the surface with a clean clothe. It is very important to never use regular oven cleaners (i.e. Easy Off ) in a self cleaning model. If you need to spot clean something without using the Self cleaning mode you can make a paste of baking soda and water and let it sit for an hour before wiping.
As far as the top is concern, use a mild soap and a dish cloth on an everyday basis. There is products specifically designed to clean the ceran tops (good brands are "Cerama Bryte" and "CookTop", they are available at any Wal Mart) you should use one of those cream cleaner at least once a week. If something is really baked on , you can use a razor blade ( same ones ones used to removed paint off windows) or a scotch brite pad ( the blue one only.. the yellow one is too abrasive)
Mar 14, 2011 | GE Ovens
Can't turn the knob to self clean on my ariston fan oven
Before you figure that out let me caution you... there are many problems caused by the self clean feature...
here is a tip that I wrote about those problems...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Mar 31, 2010 | Ariston Technologies Ovens
GE Monogram Trivection - self-clean cycle with oven racks in
Hello- First off, do not use 'self clean', or as most Techs call it: "Self- Destruct".  This 'feature' cheerfully sold by the salesman destroys more oven and range components than any other failure. Now- the racks had a thin layer of grease on them when the oven tried to turn stuff inside the oven to ash.  The grease is now a hard rubbery coating on the surface of the rack.  To solve this problem, you must determine by observation, where the rack touches the sides of the oven. These contact areas need to be cleaned thoroughly with scotchbrite and a small portion of oven cleaner. Make sure you use gloves. Sliding rack in and out to 'mark' these small spots works pretty good.  Once cleaned and wiped down, they should work fine. I recommend cleaning by removing as much 'stuff' by scraping and wiping down with moist cloth.  Turn on to 450deg for 30 min.  Much safer, less costly.                                                       Please acknowledge this posted solution if helpful.  Have more info if needed-  Thanks  -Ed
Mar 24, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
I have never used a self cleaning oven.i have already put oven cleaner on the inside and let it stand for awhile is this right? god I don't want to blow up
You DO NOT use a oven cleaner with a self cleaning cycle. Wipe out the oven cleaner as instructed on the can. Oven cleaner is better than self clean cycles anyway. Most self clean cycles eventually cause oven control problems.
Oct 08, 2009 | GE JGRP20 Gas Single Oven
How to clean oven
We called a neighbor who has a similar oven. Thanks for you interest. Utne
Dec 13, 2008 | Dacor ECD230 Epicure Electric Double Oven
Ovens Logo
123 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
