Question about Cameras
I cannot get my dv182 to link with my laptop.
How do we connect DS to a tv
This is a common question. If you go to the link below, you will find a comprehensive Tutorial. With this I am sure you will have no trouble setting it all up. http://tv.about.com/od/learningcenter/ss/connectcamtv.htm
Mar 12, 2010 | DSC DV182 Camcorder
Digir8 dv182 help uploading content from sd card
you should purchase a sd card reader, they are very cheap. ( ebay, amazon etc )
May 18, 2017 | DSC DV182 Camcorder
DV182 keep saying check card protect switch
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 08, 2009 | DSC DV182 Camcorder
Sd card not reconsized by pc
omg same thing keeps happening i have a vista and i try to download the photo's on my vista but it won't work
Jul 06, 2008 | DSC DV182 Camcorder
DV182
Ok, i don't know if you read it but i have the answer. I bought the same one and i had the same problem. I bought a 2GB SDCard too. It wasnt work... so i was looking for in the Internet, and I saw that this Camera only accept SDCards from 64Mb to 1GB. I tried with a 1GB SDCard and it worked. Good Luck!!
Khalid87
Mar 21, 2008 | DSC DV182 Camcorder
DSC DV182 I can not get the camera to store videos or photos
is your sd card > 2 gb?
only supports up to 2gb
Mar 14, 2008 | DSC DV182 Camcorder
Won't Fire up!
The memory card that you have may be too big for the camera, i did the same I bought a 4g card and the camera can only handle a 2g card try this and see what happens
Feb 20, 2008 | DSC DV182 Camcorder
DIGIGR8 DV182 Camcorder
take the sd card out and use an sdcard reader.
don't believe the drivers for the cam are vista compatible
Jan 01, 2008 | DSC DV182 Camcorder
Digigr8 dv183
when you take a photo you get the date/timeis 2002/02/05 15:01:10
can I fix the date/time?
Nov 04, 2007 | DSC DV182 Camcorder
Cameras Logo
15 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
