Question about Cameras
Hi the charging socket has broken/come loose and I need to take the bottom panel out so I can have a look at it I have taken the two screws out but the panel wont move does the back have to unclip as well if so how? Cheers, Andrew.
  • 770 Answers
Unless you are REALLY electronically inclined, there is very little you can do. If you were to get the camera apart, then determine the issue, you would have to be versed in microscopic soldering to make the repair, and that is if there were no other part required. Unfortunately, what you are attempting to repair requires HIGHLY skilled techs, that are familiar with your brand and model of camera. No easy fix for you unless you are very maticulious, and precise. Also, once disassembled, the problem would have to be obvious. Would not recommend this repair to a novice
Posted on Oct 05, 2009
650 Bandit S high beam stopped working changed bulb but blew that one, there is burning across the back of bulb any ideas?
Hi, Tez if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
P.S. the bottom link is a free service manual with a wiring diagram in the last chapter.
Why are my bulbs blowing
Headlight Bulb Keeps Blowing
Headlight bulb keeps blowing please help me its expensive
http://www.manualdoautomovel.com.br/areatecnica/manuais_de_motos/manuais_de_motos/manual_de_servicos_gsf650_s_2004.pdf
Jul 25, 2016 | Suzuki Motorcycles
On our GE Spacemaker model JVM1350 the socket for the surface/nite light is loose enough that tie bulb and socket wiggle when the door is opened or closed such that the light flickers off and on. I thought...
In most cases the bottom panel can be removed if not the whole unit will have to be dropped. If the bulb is not loose u can bend the center conductor of the socket out for better connection. Or just replace the socket.
Apr 30, 2014 | GE SpaceMaker Microwave Ovens
Headlight fuse location
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
3. Worn, chafed, or broken wires in the light circuit.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil
11. Faulty voltage regulator/rectifier ground or overcharging.
Good luck and have a wonderful day.
Jan 05, 2014 | Honda Motorcycles
How to remove a radio in 1997 lesabre
The key to this dash is the large number of hidden screws.
First, the long "woodgrain" panel that stretches all the way across the dash needs to come off. It's just held in with clips. Start all the way by the passenger door and pull the end of the panel until it pops loose. Work your way back toward the driver's side, popping the connectors loose as you go. You'll also have to remove the small strip on the driver's side of the steering wheel.
Next, all four dash vents need to be removed. Basically, turn the vent piece as far as it will go in either direction, then pop it out. It's held in by little sockets on the top and bottom, but it will pop out fairly easily. (The bottom socket is slightly larger than the top one; keep this in mind when it's time to put them back in).
Inside each vent opening, at the top, you'll find a 9/32" hex screw. Also, there are several screws along the length of the lower part of the dash panel, under the "woodgrain" trim piece you removed first. Take out all these screws.
Next, set your parking brake, turn the key on, and move shifter to a position where it's out of the way. Tilt the steering wheel to its lowest position. You're going to remove the entire dash panel that runs all the way across the front of the dash. Once all the screws are out, it's just held in with more clips. Pull the top part loose first, then pull the entire panel upward and outward to free up the bottom.
The radio is held in with five screws. Don't miss the two recessed screws at the bottom.
Dec 21, 2012 | 1997 Buick LeSabre
Hi my phone charger port on my Sanyo 2700 is loose and my phone won't charge. How do I get it fixed?
Follow this steps.
* Need to visit your nearest mobile spare parts shop.
* Take a brand new charger socket.
* Remove your mobile panel.
* Then remove the screws.
* There you can find your mobile board.
* At the bottom of your mobile you can find the charger port.
* Remove that full socket.
* Place there your new socket.
* Then try to charge it.
* After getting conformation you can fix your Panel.
Thanks for your question.Thanks for using fixya.
Jul 13, 2011 | Cell Phones
My nokia e63 does not charge. I buy new battery but same problem were encountered. What will I do? tnx n good day.
Does work all ok and dont charge? Maybe its broken dc jack connector, or the charger or a fuse inside. Try with usb on pc some nokia can charge from pc.
Jun 30, 2011 | Nokia E63 Cell Phone
Laptop dead, powercable ok. but the cable into the socket loose.
do not try at home unless you have the knowledge how to do it coz all the screw beneth the noatbook are product specific where as the problem you mentioned it needs to be taken to the service station it may be the that the solder is loose need to be fixed..
Sep 16, 2009 | NEC Versa VX Notebook
How to fix a new window regulator
normally on the honda models there are two screws that need to be taken out, the inside latch area (plastic cap covering it) and the door pull (normally down in the bottom covered with a plastic cap), thin small flat blade will work to remove. once the is done you will need to pull out the latch area on the passenger door or the driver window control panel, disconnect the connectors. set the aside, next you will need a thin flat blade screw driver or flat pry bay, start at the bottom of the door to pry out the panel ( will make a loud snapping or popping noise, this is normal) once you have loosened the panel, you will need to remove the plastic covering the access to the mirror (small triangle black plastic piece). this should now allow you to set the door panel aside, check to make sure you have removed all the clips. carefully remove the plastic lining cover the door, try not to tear or rip it. now you will need to remove the glass, there are two holes the allow access to the bolts for the window, connect your Power window switch and raise or lower till you can see them ( possibly a 10 mm socket) unscrew and set aside, hold the top of the window with one hand and lower the window to separate it form the brace. tilt the front side of the window down and remove glass set aside, now there are three screws for the regulator ( normally around the center of the door) and 4 crews or bolts , two on each window track, top and bottom) remove both bolts on each side. at this point everything should be loose, you will need to twist to get all the old parts out, replace your new parts and re assemble as you have taken apart, most cases this is about three to four hours, Good Luck !!!
Sep 12, 2009 | 2000 Honda Civic
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Cameras Logo
15 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
