Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi wd62525 replaced lamp still no picture
Lamp comes on for 4 seconds then goes out with timer light flashing
green then lamp light is red
  • Mitsubishi Master
  • 5,138 Answers
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Posted on Oct 05, 2009
I have a mitsubishi 62" wd62525, I replaced all
When you unplug the set it then when powered up waits for the DM unit to boot up----the green light blinks on the front for about 70 seconds and when it goes out the set can be turned on.
If this is the case I have a suggestion, let me know if I have described the situation correctly.
SD TECH
Oct 25, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd-60735 no picture and red lamp light stays on
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Constant flashing green light
I had the same problem. When I checked the lamp (that was only 6 months old) it looked good. I had a tech come out and he put in a new lamp and solved the problem.
Good Luck!
Apr 14, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
WD-52525-Code 34-Sound OK-No picture!
I had another problem kinda the same and emailed ctechnicians.com and they gave the fix.
Nov 02, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
292 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
