Question about Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
How do you put a new pull cord on? - Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer
    Problem Solver:
  • 16 Answers
With great difficulty on that machine!!!
Its a "Half Cranked" engine (which is cheap and nasty) meaing the recoil / pull cord is located between the shaft of the brushcutter and the engine (NOT on top of the engine like proper "Full Cranked" engines are).
You will have to remove the engine to do this and probably loose the will to live in the process! Bin it and buy a Stihl bent shaft trimmer instead
Posted on Oct 13, 2009
What do i do to put new pull cord in husqvarna Lawn edger
Remove pull starter off and wind on the new cord then wind up the spring tension so it recoils.
Aug 31, 2014 | Husqvarna Garden
Replace pull cord
Go o you tube on line, how to replace pull cord mower
May 24, 2014 | Champion International Champion& Small...
Replace broken pull cord
the way i done this was drilling out the rivets,replacing the cord and putting new rivets back in.if you dont have new rivets or the tool to put them in with you can use self tapping screws instead. i hope this helps you out?
Feb 19, 2014 | Garden
Pull cord hard to pull and won't reel back in
should never pull cord unless correct amount of oil is in it !, My advise take back to sears and buy a Toro ! Did you have the blade break lever pulled back ?
Oct 11, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
How to put a new pull rope on it How do I put a new pull rope on
It realy depends on what model we are talking about, so i will give a general disciption, remove the four screws retaining the starter to the saw, remove the starter, if the cord is still under tention, pull the starter handle out approx 8", whilst held out hold the pulley to stop it retracting, let go the starter handle and unwind the now lose cord from around the pulley, once enough cord has been unwound let the pulley slowly turn until all the spring tention has gone, remove the center fixing screw, and remove the pulley, pull the old cord away, refit a new suitable diameter cord, knot the end and pull the cord into the pulley so as the knot sits flush into the hole in the pulley, wind the cord fully around the pulley,now refit the pulley to the cover, refit the centre screw ,push the other end of the cord through the cover eyelet and refit the starter handle with a suitable knot, now wind the cord around the pulley a further two times by turning the pulley and winding up the spring, allow the spring to pull the cord in, if required wind the pulley a further turn until the cord is suitably tentioned in the cover, replace the cover on the machine, pull the cord out to make sure it has engaged fully into the pawls before fully tightening the fixing screws.
Aug 18, 2011 | Husqvarna Chain Saw 20" Bar
Rope needs rewound, got tangled up , had to remove the 4 nuts, now need to get in back on wound tight
I assume that you are speaking of a pull start mechanism.
I can not imagine how to put a put pull starter back on "wound tight". Your pulling on the cord tightens a spring which pulls the cord back in. They go back together with the cord fully wound onto the spool.
Usually, I only take these apart to replace the cord. Wind the new cord onto the spool without handle. Reassemble, then pull out on the cord a little when attaching the handle to the cord. This is the only way to get tension onto the spring at the fully retracted position because the catch for the spring is on the machine and the spring itself is on the underside what you are assembling.
If you do not wish to shorten the cord or replace it, then remove the handle, assemble enough to catch the spring, wind one turn tighter then feed rope through hole and reattach handle. Easier said than done.
If your spring is broken, then you will be needing a new one.
:o)
Jun 03, 2011 | Craftsman Garden
My pull cord on my polaris ind xlt broke can i put it back on
YOU WILL HAVE TO REMOVE YOUR RECOIL TO PUT A NEW PULL CORD IN. THIS IS DONE BY REMOVING THE EXHAUST THAN REMOVE YOUR RECOIL ASSEMBLY. BE SURE TO WIND THE RECOIL BEFORE INSTALLING YOUR NEW PULL GORD.
Dec 20, 2010 | Polaris New Genuine Polaris Snowmobile...
Lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
May 04, 2010 | Mtd 22" Yard Machine Push Mower
Trying to replace pull cord for kee tm22 push mower. new cord will not retract. replaced with new cord and now cord will not retract when pulled. spring came out while removing old cord but replaced in...
Take off the whole assembly, find and replace the spring, manuually wind up the reel until it is loaded with tension in the direction that will retract the cord. THEN put new cord in through the feedhole then the assembly, then tie a small figure eight knot at the very end of the pull cord, pull it tight so it stays in its recess and then let the cord retract by releasing the tension. - you now have a fully charged retractor assembly. put it on tightly with the three 10mm bolts, reattach the plastic cover and git mowin.
Mar 27, 2010 | Garden
Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Mar 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Ryobi 30 Cubic Centimeter Curved Shaft Gas Trimmer Logo
257 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
