How do i set ip address for new jet direct card on hp 4600 dn
    Scholar:
  • 82 Answers
Go here for the manual cause it's a bit hard to walkthrough. When the printer is on and ready, you want to click the menu button and scroll though to the configuration menu -> i/o menu. You can print a configuration age to see what the current address of the jetdirect card is. If you're comfortable with command line, you cna use telnet to connect to the jetdirect card and configure it that way.
Posted on Oct 05, 2009
  • 36 Answers
Assuming that DHCP is enabled on your network, the printer should obtain an IP automatically. Print a configuration page to determine what IP it's using:
Print a configuration page to ensure that the printer is working properly.
1. Press Menu or Select (check mark)
2. Press the Down arrow until Information is highlighted.
3. Press Select (check mark).
4. Press the Down arrow until Print Configuration is highlighted.
5. Press Select (check mark) to print the page.
If the configuration page does not print, consult the CD version of the HP color LaserJet 4600 Series Printer User Guide.
You can then put the IP in the Address bar of your favorite web browser to go to the Jet Direct's webpage and set a static IP for the printer. (Make sure to use an IP that is NOT in your DHCP scope.)
How to remove the jet connect card from a hp laserjet 4015 dn printer
It is held in with 2 screws. Remove the screws and carefully remove the jet direct card. Note: the jetdirect card is where your network cable plugs in.
Jul 15, 2014 | HP Laserjet P4015x Printer
Set up wirelessprinter hp
INSTALLING A NETWORK PRINTER These instructions generally apply to all network printers with built-in network cards (print servers) such as HP LaserJet printers, IBM Infoprint laser printers etc. This example is for a network HP LaserJet printer. To install a HP printer (with built-in Jetdirect print server) as a network printer on a wireless network . You need to do the following -
1. Open the printer\'s menu and enable the Network Card - these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP\'s are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network). Then set the Subnet Mask IP address to 255.255.255.0 If you have a wireless router then check the IP address range that the router issues to the computers on your network and configure the static IP address in the printer\'s network configuration accordingly.
2. Install the HP printer driver on your computer/s using the LPT printer port.
3. Connect the printer with a LAN cable to the network hub/router.
4. Click on Printers and Faxes - right click on the HP printer and click on Properties.
5. Click on Ports and click on Add Port.
6. In available ports - click on Standard TCP/IP Port and then Configure port.
7. Tick the IP box and type in the IP address of the HP\'s printer IP address.
8. Click OK and tick Enable bi-directional support and then OK
9. Remove the printer cable, then do a test print to see if the printer prints correctly.
Install the HP printer driver on every computer on your network and configure the printer\'s TCP/IP port as previously detailed. Do a test print page to check the printer.
You can now print from any computer on your network.
Jan 28, 2013 | Office Equipment & Supplies
We have a networked HP Laserjet 4100; a new PC was added and the printer does not show as available on the network for this new Dell Vostro 460. The driver was installed and still nothing. Can you suggest...
Thank you for contacting FixYa with your printer inquiry.
This is usually a pretty common network problem for printers and other devices on a network. If you network uses DHCP that automatically assigns IP address's you may have developed a conflict when you installed your new printer.
You will want to print a configuration page from both printers to determine what the IP address of each is then manually configure independent IP address for each to preclude further conflicts.
Refer to this excellent HP document page on the LJ4100 Jet Direct Card for manual configuration:
http://www.printerhacks.com/how-to-setup-an-hp-laserjet-printer-with-the-built-in-jetdirect-network-card/
Hope this helps helps. Please keep us updated and remember to rate this answer.
May 10, 2011 | HP LaserJet 4100 Printer
How do i set the ip address on hp laserjet 2300n printer
First let me state that the network cards on these printers are notoriously bad and fail very often. Before attempting any settings, use the arrow keys to bring up the information menu and then printer a configuration. If you have a network cable plugged in then the configuraiton page will print both the basic pirnter configuration page and the Jet Direct status pages which will show the currently set network information. If only one page pirnts then the card is not working, if three pages print the card is working and you will be able to follow the instructions below.
Press the menu button and then use the up and down arrow buttons until "configure device" is shown and press the checkmark. Use the up and down arrows until display reads "EIO" jet direct menu then follow these menu options
Arrow down until display reads TCPip press check.
Arrow down until it reads enable, press checkmark and change option to yes, press checkmark.
Next arrow down to config method press check and then choose DHCP or manual and press check. If you have a router it will automatically assgin an address to your printer when you set it for DHCP, if not, you will need to select manual and then manually input IP address, subnet and gateway.
Once you select manual you will have the option to input the IP address, subnet and gateway using the arrow keys and the checkmark.
Mar 28, 2011 | HP LaserJet 2300N Printer
Where do you find where to put the ip address in a laserjet 4200dtn
Click on the down button on the printer. Go to "Cinfigure Device" then click the green button. Then click on the down button to "I/O Menu" in here you will click on TCP/IP then click on "enable" then you will move down to Config Method You can then select BOOTP(automatically assigns and IP Address) or DHCP Manual (where you set the IP Address, Subnet Mask, Default Gateway).
If you go to the I/O and there is no TCP/IP selection then you will need to purchase a Jet Direct Card from somewhere.
Jul 21, 2010 | HP LaserJet 4200dtn Printer
I changed the IP address range of my LAN and need to assign the new range of addresses to my HP printer P2015dn
Press the Menu button on the printer to open the printer’s menu and enable the Network Card – these print servers use a static IP address therefore, configure the IP address of the network card so it matches the IP range of your network. Eg. If your IP's are 192.168.0.xxx then set the network card to a high number say 100. (This is to prevent a conflict with the router issuing the same IP address to a computer on your network).
Jan 13, 2010 | HP LaserJet P2015dn Printer
I am on a network with a brand new HP 8500. I have searched for the printer and my laptop doesn't pick it up. What amI missing?
Have you checked that the IP range for the printer is on the same IP range for your network? you could always cold reset the printer which will reset the network card back to zero's. You attach it to the network and your server should issue an IP address via DHCP. You should be able to see it on the network then.If not, the jetdirect network card may be at fault.Has the printer got a Jetdirect network card installed?
Oct 15, 2009 | HP LaserJet 8500 Color Printer
HP P2015dn wirless connection stopped working
There is not wireless netwrok card is HP LJ P2015dn, However as i can understand you r using External Wireless Router or Wireless network or jet-direct card if u r able to work fine on USB than printer printing mechanism is working fine.
If u connect the printer via wired network connection and it keeps on loosing IP address than it may be problem with onboard network card of the printer.
If printer keeps on loosing IP Address than try upgrading the firmware of the printer.
To check the firmware and IP Address of the printer print a configuration page by pressing and holding down green button for 6 to 7 seconds
May 28, 2009 | HP LaserJet P2015dn Printer
HP Color LaserJet 4600 Keeps Calibrating
Replace the Jet direct card in it. I had a similar problem and replaced the Jet Direct card, all was good never had that problem again.
Apr 15, 2009 | HP LaserJet 4600dn Color Printer
Hp 5500 dn with 49 4C02 error
Replace the jet-direct card. don't forget to install the IP address on the new card.
Apr 14, 2009 | HP LaserJet 4350TN Printer
841 people viewed this question
k24674
