Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Wash cycle doesn't stay at 160 but drops to 150
Trouble with wash temp's
To adjust the wast or the resine temperature of the Hobart dishwaster
Posted on Sep 15, 2008
Check the high limit on the heating element and make sure its not tripped. If the high limit is fine check too see is there power going to the heating element and the amp drawing. Each leg should be reading 23.5 Approx.
Posted on Apr 09, 2008
Check Rinse temp Coming into machine needs to be 180F to keep wash temp up
Posted on Mar 02, 2008
  • 640 Answers
A ten degree drop isnt bad,what is the problem?
Posted on Dec 26, 2007
Why does my machine not wash as good as it used to?
Water temp changed? Different detergent? Overloading enough to prevent proper agitation? All these can affect the performance. Also, if drainage is slow due to clog or weak pump, it might not rinse well, leaving soapy residue as well. Whirlpool pumps are pretty cheap and easy to change, usually, should that prove to be the source of your trouble. But look for simpler causes first.
Jun 27, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
What are the temperature on the settings of washing machines?
That is a very good question. These units partially open and close
the inlet valves for certain temp settings. And if it's out of it programed tolerance the machine stops and throws up a trouble code. I'm sticking to the older machines.
Jun 26, 2014 | Kenmore Elite 45986 Front Load Washer
What is the sequence to reset kenmore dishwasher 665.16719000? The buttons from left to right are pots/pans, normal wash, water miser, china gentle, quick rinse, high temp, air dry, delay wash, start
Press "high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash"
All the lights will go solid at which point you press cancel to reset the board.
**NOTE** if you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
Apr 03, 2014 | Kenmore 24 in. 16052 Built-in Dishwasher
Kenmore Dishwasher Model 665.16719000 pushpad buttons lights flashing and won't work.
Apr 03, 2014 | Kenmore Dishwashers
The hi temp wash and air dry lights are blinking on my firgidaire dishwasher
Hi Dan, this is AP!
I understand you are experiencing some trouble with the lights on your Frigidaire dishwasher. On your particular model, FFBD1821MW, if there has been a power failure, then the "Hi-Temp Wash" and "Heat Dry" LEDs will flash. In order to stop the LED lights from flashing press Start/Cancel. This process should relieve your concern regarding the LED lights flashing. I hope this information proves helpful to some degree.
Best of luck,
Mar 25, 2014 | Frigidaire Dishwashers
Frigidaire washing machine (FTW3011KW0) runs through all cycles, agitates, pumps out water, but doesn't spin, nor does the motor attempt to spin during the spin cycle
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad.
murf427
Jul 31, 2012 | Frigidaire Washing Machines
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
439 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
