Question about Jacuzzi Home
My jacuzzi baths pump makes a noise when i turn it on and no jets work the fans not going round but if i switch on the button on the bath and manually turn the fan it kicks in and works ok
  • 125 Answers
You have a bad pump. has a bad spot on the motor, that is why it doesn't start. What model number of pump?
Posted on Nov 15, 2009
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
What cleaner gets the bad smell and crud out of jacuzzi jets?
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi Home
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Hi I have a jacuzzi. I would like to connect it DIY
You can get 2 types of Jacuzzi baths, 1 with just a pump which just jets the water via a small pump or 1 with the pump and elements that heats the water aswell as pumps the water through the jets. Because the 1 with the elements has a higher amp rating you need to run a cable from your distribution board to your bath but the 1 without the elements you will be able to tap off the nearest socket to the bath, you will be coming from your socket to a fused spur outlet, it would be better to get a switched fused spur outlet as you will be able to isolate the bath when not in use just by switching off the switch. from the spur outlet you will be wiring it into your motor on the bath, it should say the rating of the pump in amps on the tally plate of the motor or on the manual. For example if it says the motor draws 2 amps you will be putting a 3 amp fuse into your spur outlet so if there is a fault with the motor the fuse will blow instead of tripping the whole socket circuit. All jucuzzi baths has to be connected to the RCD side of your distribution board. If you are tapping off a socket don't worry about the RCD because all sockets should be on the RCD anyway, to check that the socket is connected to the RCD plug something into the socket you are tapping off of and press the test button on the RCD, the RCD should trip and while this is tripped check the lamp or whatever you plugged in shoud be off. The Fused spur should be fitted outside of the bathroom.
Mar 29, 2011 | Whirlpool Home
Were is the starter switch located on corner jacuzzi tub
Depends on the make of your bath, alot of baths has a crome button on the corner of the bath, flush with the bath top. When you press this it pushes air through a hose and the pressure of the air hits a pressure switch on the motor which turns on the motor.
Mar 29, 2011 | Home
Jets not working in my ten year old jacuzzi bath
Open pannel and look for a reset button on or near the pump motor.. Or it is posible that the pump motor is shot..
Have a great day !
Nov 11, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
Jacuzzi whirlpool hot tub, flashes Fl-1 has new filters,
Sounds like a bad heating element. This is located in a stainless steel tube under or around the main control box behind the cover around the tub. It is not hard to replace but should be done by a pro. The part is avaliable online.
Sep 24, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
My Jacuzzi won't turn off or heat
The heater will only fire if it has water in it. If you just got the house, make sure the gas/electric to the heater is on. Turn off the pump and turn it back on.. See if that works. good luck
Jun 05, 2009 | Whirlpool Jacuzzi Jacuzzi Bath Fuzion EF50...
Jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Oct 06, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Home Logo
266 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
