Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
RF mixup Hi, I have two wireless telephones and every time the phone rings I loose signal therefore every download I have going is lost. What can I do? Thanks
  • 315 Answers
You can try changing the Channel number on the SGB900 Setup program.
If its possible, wire a computer to the modem via ethernet cable or usb, this is the manufacturers prefered way.
In your internet browser address bar, type 192.168.100.1 and press enter.
This should take you to the motorola modem log in page.
These are the default login's unless you have changed them, then just use your own login.
The default log in should be:
Username: admin
Password: motorola
** These are case sensitive **
Once your logged in navigate to this section:
Click on the tab on the left side titled Wireless
Click on the the tab at the top titled Network
You should then be at a page which has the information on it like, DONT change anything here other than channel:
Enable wireless interface
ESSID
Channel
Make a note of what your previous channel was set to, then just click through them and save..
If you can ring your house phone via a mobile, you will be able to see if you lose signal and find the correct broadcast channel that isnt affected by your home phone.
As previously mentioned though if you have gone through all the channels on the modem and you still get interference then unfortunately you would need to find a phone that doesnt use the same frequency as your modem.
I hope that helps
Mike
Posted on Oct 06, 2009
  • 22 Answers
THEY ARE IN THE 2.4GHZ BAND ???
IF SO,CHANGE YOUR PHONE FOR ONE IN THE 5.8 GHZ.IT HAPPENEDO TO ME.THE PHONES ARE MESSING WITH THE WIRELESS SIGNAL OF YOUR MODEM/ROUTER.GODD LUCK.
Posted on Oct 05, 2009
Right head phone in op
It looks like you will need to open them up and look for a loose wire in both earpieces. Also, while there, check to see if the batteries are in correctly relating to polarity!
Jan 15, 2013 | Rocketfish Rf-rbwhp01 Wireless Headphones,...
How can I change the number of rings to six before it goes into answering machine on my cordless Uniden 6.0 phone?
Since you neglected to specify the model of your Uniden DECT 6.0 system I can only suggest you select it from the list beginning here to download a copy of the manual.
Nov 25, 2012 | Uniden DECT 6.0 Cordless Telephone...
I can't get a signal
Do you remember if you phone was slip against somehting?
If this is the case you must go to service shop.
If not you mus reset your cell phone.Go to the menu and see for automatic signal network, and select from your company. Otherwise you have problem with RF module in cell phone(this module contain microprocessor, wireless system, clock, RAM, etc.) .Finally call you company if they have some problem in your area.
sincereley.
Dec 08, 2011 | Sony Ericsson Cell Phones
I having a problem with frequency. My phone and my neighbor phone seems to be on the same frequency. Is there any way to change this. When her phone rings our do also. We have called the cable n At&t,...
Telephone devices connected as alternative ansering allows for one person or the other to respond especially devices at the same residence. E. g. devices may share the same line like several telephones situated in the bed room interconnected to living room telephones allowing for the same person or owner to answer from any location of the structure. A situation that the telephone connection is thought to be malfunctioning requires consultation with the networking company. Usually, an experts technician would provide separate telephone lines to each devices least interfering with responses. alternatively, wireless telephone networking with modem installations provides residential, office locations networking where several devices share signals least interfering with neigbor response resources. Contact a network structure about wireless networking, broadband networking connectivity at residences, offices, schools or elsewhere.
Jul 20, 2011 | Lands Phones
.com.aumodel WDSS 5335 1 my
There could be DC voltage on the ringer circuit. When a phone line is not in use there should be 0 Volts on the ringer circuit. Sometimes a device connected to your line can "leak" voltage on to the ringer circuit, and some phones will see this as a continuous ring signal.
1. Check all of the telephone cables and any power cables - are they securely plugged in?
2. Remove every device connected to your phone line except the phone that was ringing continuously.
3. If the ringing stops, put the devices back one at a time and see which one causes the problem.
4. If the ringing does not stop, the fault is either in the telephone or your master socket.
5. If you have another phone that is known to be working, try it out to see if it has the continuous ringing.
6. If the problem no longer occurs, there could be a problem the telephone equipment, and you should contact the telephone's manufacturer for support.
7. If the test phone has the continuous ringing, call your telephone provider and tell them that there may be a short circuit in your phone line.
8. If the problem happens only with your cordless phone, and not a corded phone, then it could be interference from a device such as a wireless broadband router or microwave or the cordless handset batteries may not be charging properly.
Mar 20, 2011 | Uniden Cordless Phone
I have mtnl connection with D-link modem (502T) My connection get disconnected in between download so is there anyway that my modem could restart it self when it looses internet connection.
Signal strength drop or fluctuation are common causes of RF interference.
Try these basic troubleshooting steps:
  • Change the channel on your access point or wireless router.
  • Change the location of your wireless products. Subtle changes (2-3 feet) can make a big difference. Do not put the access point or wireless router in a cabinet or enclosure.
  • 2.4GHz phones, X-10, and bluetooth devices will interfere with your wireless network. Change the location of the base for your phone, or downgrade to 900Mhz phones, or upgrade to 5.8GHz phones.
  • The wireless signal will degrade (or die completely) when going through brick (fireplace), metal (file cabinet), steel, lead, mirrors, water (fish tank), large appliances, glass, etc.
If your wireless connection is only dropping during large file transfers or when a large number of wireless clients are connecting, change the preamble on all wireless devices to short.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Only two rings before answering machine I want
You can set the number of rings through the base unit's menu. See the manual for details. Lost it? Go to www.uniden.com and download one.
Aug 11, 2010 | Uniden DECT 6.0 Cordless Telephone...
My phone not getting signal properly when a signal low area.some time even is signal available,cant take call to phone.
thats a hardware problem, your RF amplifier should be weak. it is responsible for amplifying and mentaining the signal on your phone. you should therefore take it to a service point so that they check it anf if possible replace it.
Regards
May 10, 2010 | Nokia 6300 Cellular Phone
I upgraded my Linksys WRV54G firmware from 2.39.2 to 2.39.2e and completely lost internet connectivity
hi there,
have you tried to reset your wireless router so that the default settings are being used, then try reconfiguring it again for your Internet connection.. then try to connect wireless again ... sounds like your router may have lost its settings which happens for some firmware upgrades.....
or
Wireless Interferences
Neighboring wireless networks or any appliance that operates on the same frequency as your wireless device (e.g. 2.4 GHz) may cause interference and therefore may affect your wireless connection and signal.
Common sources of interference are:
  • Neighboring wireless networks
  • Microwave ovens
  • 2.4 GHz cordless telephones
  • Bluetooth devices
  • Wireless baby monitors
To solve the problem, change the channel and SSID on your Access Point. Preferred channels to use are 1, 6 and 11 since they’re considered non-overlapping channels.
May 01, 2008 | Computers & Internet
Md 760 series cordless telephone system
Try unplugging all telephone (including the base unit), then try to call the number again. If there is still a busy signal, then the problem is with your telephone line/connection and you need to call your phone provider. On the other hand if the number rings, then chances are that base unit is defective (or one of your other phones physically connected to the tel line.).
To verify that it is the base unit or one of the other wired telephones,  reconnect them one by one and determine which of them will cause the busy signal. Problems like this can be caused by a power surge, near lightning strike or a simple component failure.
If it is the base unit, it is very likely an electronic problem and therefore would require familiarity with components and circuitry diagnosis, soldering and use of a DVM. Perhaps your best bet would be to seek the services of a qualified phone technician.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 02, 2007 | Motorola Mobility MD761 Cordless Phone
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
239 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
