Question about Brother MFC 420CN All-In-One InkJet Printer
THE PRINTER WONT WORK IT JUST KEEPS SAYING NO PAPER FED WHEN PAPER IS FED
  • 466 Answers
First of all, check that the paper size setting is correct in the printer and in your software. Sometimes the printer tries to tell you not that "there is no paper" but that "there is no PROPER paper", e.g., you send a B5 printing job when the printer has A4 paper in it.
If this is not the case, we have to assume the problem is hardware.
Take out the paper and look where the paper should go. Insert a single sheet and look along it for help. You should see a small plastic leg dangling down from the left upper hand side of the paper feed slot. That's the paper out sensor.
If you can't see it, it could be broken - in that case the printer will never see the paper you put in. Or it could have stuck in the forward direction (it can happen if somebody overfeeds the printer or tries "snatching" the paper when it's half captured by the rubber roller). If this is the case, GENTLY rapping on it may dislodge it and send it dangling properly on the paper path.
If you can see it, and it dangles properly - it's not skewed or bent and does not appear damaged - try blowing along it with a compressed air can. Sometimes a bit of paper dust can lodge in the optoelectronic "window" and blinds the sensor.
All other likely damages, unfortunately, aren't easily repairable except by a skilled technician with the appropriate spare part.
Posted on Oct 05, 2009
4 Suggested Answers
  • 86 Answers
SOURCE: The printer keeps saying No paper fed.
the paper sensor is dirty or something is blocking it
Posted on Oct 19, 2009
Patzky
  • 240 Answers
SOURCE: Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Posted on Mar 24, 2010
caroldon
  • 17130 Answers
SOURCE: ip5000 printer worked perfectly but now comes up
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken .
Hope this will help or else you mother board has errrors.
Posted on Sep 28, 2010
My HP officejet Pro L7680 cannot scan anymore. It keeps saying: "Reload the Document & restart the job. And when scaning through PC then give an error msg: "The automatic Document deeder is...
does the feeder try to fed the paper? if you hear not working and not fed the paper then clean with alcohol with hard paper the roller .
if not fix did you hear noises? maybe the gears.
hope i help
Dec 02, 2010 | HP Officejet Pro L7680 All-In-One Printer
Ip5000 printer worked perfectly but now comes up with three orange lights stating a paper jam. There is no jam. Shop says it is a timing problem but suggested a new printer. Paper roller keeps rolling...
Sep 28, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
It says load paper....It has paper? It wont detect it? What can I do?
make sure that the paper drawer is all the way in and nothing is holding it out even a 1/4 inch. also check the source that the printer is drawing the paper from in the printer settings if this unit can be fed from different paper supplies.
Regards
May 20, 2010 | Dell 3000cn Laser Printer
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
Oct 19, 2009 | Brother DCP 115C All-In-One InkJet Printer
Keeps saying "paper out" when paper tray is full
Reduce the quantity of paper fed to the printer.
Mar 31, 2009 | Dell 922 All-In-One InkJet Printer
My Brother MFC 465-CN keeps saying "No paper fed"
try cleaning the paper feed roller with isopropal alcahol
Nov 26, 2008 | Brother MFC-465CN InkJet Printer
No paper fed
Pull the paper tray out, then turn the printer on it's side. There is a mechanisim that has some rubber band type grips that pick the paper up. Pull them off, turn them inside out and put them back on. Give it another try.
Jul 23, 2008 | Lexmark E234 Laser Printer
Paper feedin
The price of labor and repair parts could exceed the cost of a new printer in some cases. This most likely wouldn't be something you might be able to repair yourself. I would call the authorized repair center in your area and ask about a quote on what it might cost to repair this printer.
Jan 15, 2008 | Brother MFC-5860CN InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
94 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
