Question about General Electric GHDA485NCS Built-in Dishwasher
I have a ge model ghda485 that is not draining, as per owner's manual i have an air gap. the indicator lights are blinking and but the unit does not drain. unit was working ok untill this problem cropped up. pls help........
  • 62 Answers
SOURCE: Blinking "rinse only" & "cancel drain" indicator lights
have you unpluged for 5-10mins? check manual for fault codes..genrally in rear. Sorta sounds like a drain problem...maybe...very common.
Posted on Jan 03, 2008
  • 171 Answers
SOURCE: dishwasher
Hi lilwing,
I'm Harvey the Master Plumber.
Your question is: you have a ge dishwasher you purchased two years ago. you have misplaced your owners manual. you can only tell you it is a ge quietpower 3. you don't even know the model since you've misplaced your owners manual. it started with the timer for speed cycle set itself between 50 and 60 minutes, and you knew that wasn't right. and then yesterday it did not drain all the water out. you know there is no food particles in it because you clean them before you put them in the washer and the drain line it is hooked up to is working proberly also. can i help?
First, the model and serial numbers are in the door jam. Open the door and look right and left.
The rest sounds like a bad control board, It will require a pro. If the d/w has a few years on it you may want to consider the price of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Posted on Sep 23, 2008
SOURCE: GE dishwasher, model #gsd4000j00bb, won't drain.
I just posted the soloution that I found for this problem to another question. I found a bone stuck in the impeller of the discharge pump. Requires that you pull the unit out turn it on its side (rather messy and everything needs to get disconected as if you were going to remove the unit from the house and install a new one). Find the discharge pump and remove the cover (I pulled a 2.5" rib bone chip) remove the blockage, button everything back up, hook it all up slide it back in and now mine works.
Posted on Feb 09, 2009
SOURCE: water in bottom of GE Nautilus dishwasher
I was having the same problem and downloaded a copy of the manual and found out it is normal for a couple of inches to remain in the tub! I can't remember where I downloaded the manual, but you can "Google" it like I did. Hope this helps :o)
Posted on May 19, 2009
Does the GE APE08AJM1 air conditioner come with a dehumiderfer on it?
Yes, the unit has a 4 pint per hour dehumidifier as one of it's features.
More information on this model portable AC unit and a look at & print it's Owner's Manual, click on the following link. http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=APN10AA
I hope this helped you and thanks for choosing FixYa.
Sep 07, 2011 | GE APN10AA Portable Air Conditioner
Unit keeps shutting off and blinking all three lights.
When what you described occurs, it's an indication that the water collection tank is FULL and needs to be drained, before normal operation will continue.
In case you have misplaced the Owner's Manual to your unit, I have included a link to it that you can download & print for future reference . http://www.sharpusa.com/CustomerSupport/search.aspx?q=CV-P10MX
I hope this helped you & thanks for choosing FixYa.
Aug 24, 2011 | Sharp CV-P10MX Air Conditioner
After unit has been charged for a couple of hours, the meter indicator light, as per the manual, is suposed to start blinking. Mine never has blinked.
I have several of these units and their lights have never blinked either. Just charge it until the green light comes on and that should be sufficient.
Oct 20, 2010 | Vector 1 Million Power Series Spotlight &...
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
GE dishwasher will not drain. Does not appear to be clogged.
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Aug 27, 2009 | GE Dishwashers
Ge quietpower 3 wont turn on
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or Control Board
Aug 05, 2009 | General Electric Adora GHDA670N Built-in...
GE Model gsd5330d00ww will not drain. There are no drain obstructions and I have replaced the piston gasket in the rear of the tub. What is my next step in figuring out the problem?
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer/control
Jul 30, 2009 | Dishwashers
My GE. quiet quiet power plus won't drain
This is normally a pump issue. check the following to combat this further..
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 11, 2009 | GE Dishwashers
Ge nuatilus wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or control board
Jun 03, 2009 | GE Nautilus 24" Built-in Dishwasher
GE DISWASHER - PDW7300J00WW- WATER STANDING IN BASE OF UNIT - WATER DOESN'T DRAIN. CHECKED HOSE TO DISPOSAL AND TO UNIT IT IS FREE OF OBSTRUCTIONS? wHAT NEXT?
Check the following to address this issue--
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 03, 2009 | GE 24 in. Profile PDW7800 Built-in...
General Electric GHDA485NCS Built-in Dishwasher Logo
151 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
