Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Very hot wires and very hot battery bornes
I wrote in title my problem . Thank you.
  • 881 Answers
Hot wires and hot battery
1 charging much to high
2dead short in wiring
Posted on Oct 06, 2009
Testimonial: "Thanks for answer but my wires are hot in function not in charge when I put my MotorGuide 46 on stage 3,4,5"
My lawn tractor(model#502.255190 or193)keeps blowing solenoids.Except for the hot wire going to the battery there are only two wires. One(red) goes to towards the engine and has a fuse. The other wire
check the voltage to the solenoid coil when attampting to start the engine, you can also remove the 10ga. wire from the starter and check it that way too. with the starter motor spinning your voltage to the solenoid coil (the small wires) should be no less than 8-9 volts. With the starter spinning voltage to the starter should be about the same, anything less and you could be dealing with a bad connection at the battery, solenoid or the wire ends themselves. Of course all of this is assuming the battery is healthy and fully charged, weak batteries kill starter motors and starter solenoids, it makes them get real hot and fail prematurely.
Jul 17, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
New battery new alternator battery still wont charge ??
91 , (is the charge lamp glowing key on, (shoe drops)?????
there are many ways to make it stop doing 13.3v to 15vdc running,
lots. ill list them all..
the 2 stated. in blue above. and.
1: bad dash lamp this lamp boot staps the field current or the alternator is born dead. so is it dead key on, , yes, BINGO.
2: bad alt ground, or starter top bolt , ground to battery bad or loose.
3: bad wires to the rear of alt. all 3.
4: bad battery cables. (or just corroded ends or conn. wrong)!!!
5: alt belt loose or missing.
6: engine hot RPM not 750 to 850 Rpm if 500 BINGO.
and more.
http://www.fixkick.com/Charging/charging.html
here is the drawing.
IS the sense wire is dead, not 12vdc.???
http://www.fixkick.com/Charging/charge89.jpg
the reg inside can shut the ALT down for.
over voltage
over current.
or if it THINKS(sic) that the batter internal resistances is too high. for ANY REASON what so ever. it will shut down
these protections prevents the ALt. from blowing expensive electronics (all of it) to kingdom come. $$$$$
its a feature.
Jul 08, 2014 | 1991 Suzuki Sidekick
The heat coming out of ny dryer is to hot , the duct is way to hot to touch .model # yrel3613b(maybe 8)w2 thank-you
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Sep 06, 2011 | Roper Dryers
How do I explain to a 6 year old child why she is younger with a birthdate of 2/1/2004 than someone with a birthdate of 2/27/1988? She feels she shoudl be older because her birthday is 2/1 and the other...
why correct her? that just cute she will learn it eventually...
make her count backwards starting with the current year,
a new born baby born today is how old?
what if that baby was born last year?
the year before?
it will click
Feb 26, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
Lost keys have hot wired it wont start but does turn over wants to go what do i do
Take your title to the dealer, they should be able to make you a key, also do you hot wire hot to ACC/ON hit Start, then release back to on when it turns over? It may not run if you have anti-theft.
Dec 13, 2009 | 1990 Audi 100
Cleaned complete machine now wont start
the starter itself should ground to the engine and the engine should ground to the battery you should trace back the ground lead from the battery to the engine if that is good use a light tester or volt meter to check your hot wire to the starter and your other hot wire from the solenoid to the switch to the battery although that should be good if you can jump it at the terminals if nothing else you can always connect a new hot wire from the switch to the solenoid if that doesn't work replace the solenoid itself
Apr 04, 2009 | Welding Tools
DT 125 R will not start
Just to eliminate the most-obvious; you have checked for continuity/power through the killswitch on the right bar, and for all your fuses,yes
Nov 10, 2008 | 2004 Yamaha DT 125 R
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
255 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
Mike Marcotte
Mike Marcotte
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
