Question about Kodak DCS Pro SLR/n Digital Camera
RAM configuration error message? What to do?
Receiving RAM configuration error message? What to do? Leading up to this the camera kept freezing when saving an image. The red save light would just keep blinking., and eventually a card error message would appear or I would have to turn power off AND pull battery.
  • 75 Answers
SOURCE: WHY IS MY CAMERA NOT STAYING ON ?
It sounds like the memory card slot has been damaged in some way. This probably means a new circuit. I would suggest you find a Kodak service centre in your area. Hopefully the camera is still under warranty.
Posted on Mar 28, 2007
Agent Allan
  • 480 Answers
SOURCE: Kodak memory card error
Hey hardygurl198,
What is most likely going on is you need to format the card so it will work in your camera. Every time you get a new memory card for a digital camera or if you put a memory card formatted to a different camera in a new digital camera you will need to format the memory card before you can use it. Directions on how to format your memory card are on page 27 of your camera manual, and I have provided a link to a PDF download of your manual in case you need it. I hope this helps!
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00431/C310_CD40_GLB_en.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jul 08, 2008
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Posted on Jun 06, 2010
  • 11967 Answers
SOURCE: My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
Posted on Jun 07, 2010
Tri3mast
  • 747 Answers
SOURCE: The camera keeps saying "Memory
It's not the camera. I hope you have the original card if not no matter. I'm including a diagram that shows a locking switch on an SD card the black arrow points to the little switch in the unlock position. Now something else you will need to format the memory card to make it compatible to your camera. This function is in "set up" and you need to use the arrow keys to navigate to that function. Format the card and everyone will be happy again. Another thing each time you download pictures to your computer you need to format the memory card. What I expect you are doing or have been doing is deleting the pictures. This works but eventually it leaves the card full of holes and dirty and the camera can no longer write to it. I full expect that if you still have the original SD car that you can format it as well and it will work again. Now saying that because it's so dirty (with old deleted information not actual dirt) you may need to format that card a few times (maybe twice). This will solve your problem
Diagram
Posted on Jan 07, 2011
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-5300 Digital Camera
Card Error If have a warning message "CARD ERROR" in the LCD Display. what shuold I do?
Sep 11, 2005 | Toshiba PDR-5 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-4300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3340 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3330 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
Card Error
Sep 11, 2005 | Toshiba PDR-2300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-2 Digital Camera
Kodak DCS Pro SLR/n Digital Camera Logo
20 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
