Question about Dryers
I have a kenmoore stack washer and dryer, the dryer was running and stopped it and took clothes out and about 10 min later after I stopped it I heard the buzzer go off and smoke was coming out of it. I unplugged the unit and havent used it since. i still use the washer part but am afraid to use the dryer do you have any idea what this could be. thank you
  • 770 Answers
When you have smoke coming from a dryer, the most likely cause is lint on the element. Clean the element, clean the lint trap filter, (AFTER EACH AND EVERY LOAD), and make sure your vent is clear, free from lint and moisture.
Posted on Oct 05, 2009
Testimonial: "thank you! very much i will try it."
My Kemore stackable dryer does not work properly. I have to run the dryer 3 or 4 times to dry a load. Does feel hot at times when I open the dryer and feel the clothes.
Perhaps you have an air restriction of some sort. Cleaning the dryer and checking the vent can greatly increase efficiency. I recently replaced the glides and belt on one of these and made some repair photos. The dryer was plum full of lint all over the controls and everywhere. I took a shop vac to it before I snapped the pictures later that day. I have included a manual also HERE.
Dec 27, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washer and dryer do not work
wires were shorting each other out that go into plug - once took apart saw the sparks so just cut and shortened wires and reconnected them to plug
Jan 27, 2009 | Maytag LSE7806A Top Load Stacked...
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Kenmore 98702 Stacked Washer keeps stopping, and a smell of smoke.
More than likely there is something locking up your motor. Either the transmission or the drain pump, both are connected to the motor. The easiest way is to disconnect the components from the motor to determine which one is causing the problem. Most of the time it is from the something being lodged in the pump, a sock, screw, wire, etc. To get to the pump you need to tip the washer back far enough to get underneath the washer.
Jul 27, 2008 | Kenmore 98702 Stacked Washer/Dryer
Stacked Maytag Neptune - Accessing Inertial imb/Upper tub disp Switches
The switches you are referring to are set-reset. These rarely have a fault. Normally the machine control board is the faulty component. How did you determine that these switches are faulty ?
The safest way to access the upper portion of the washer is to remove the dryer. Another method is to remove the "complete" washer front and the control panel. This will give you access to the top of the washer tub.
Jan 04, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Kenmore Stackable Washer/Dryer
THIS COULD BE THE MOTOR IF IT IS UNDER WARRANTY LET THEM PAY FOR THE REPAIRS
Dec 27, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
60 people viewed this question
Top Dryers Experts
