Question about LG 42LC2D 42 in. LCD HDTV
LG 42 LCD tv is smoking and zapping on back left and will not turn on. Does not look good!! TV is only 15 months old so out of warranty. LG TV's are not good!!
  • vinnyq
    vinnyq May 11, 2010
    Do you get any sort of standby or failure blinks? If not, the power supply is bad.
  • 8457 Answers
SOURCE: LG M4201C 42" will not power on.
Power supply board is dead.Must change the power supply board.Tries shopjimmy.com,Ebay.com for the part.
Posted on Jan 23, 2010
SOURCE: I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Posted on Feb 05, 2010
toyladi3
  • 597 Answers
SOURCE: OUR 11 MONTH OLD 42" LG PLASMA WONT TURN ON THIS
There is a problem with the power panel/pack of the television. It must have gotten burnt that is why your television is not coming up. If the green dot does not appear when you use a DVD player to watch a movie on the television, then the problem is not from the television, but if the green dot appears all the time, then it simply means there is a cold joint. Which means, there is melted lead from a panel in the tv.
But since it is under the warranty period, it will be best you take it back to the dealer that supplied it to you, because it is less than a year and it is giving faults,
All the best.
Take care and good luck
Posted on Oct 11, 2010
  • 19 Answers
SOURCE: my LG 42" LCD turns
first your going to need to disconnect any wires from the tv. then unplug the tv from its powersource (ex- outlet) then make sure no power is still stored within its capacitor by pressing the power button for five seconds. then lay down a plastic mat underneath the tv. then your going to need a phillips head screw driver, an allen wrench and a small rubber hammer. turn the tv around and using the screw driver remove the screws from the back of the tv, on your particular tv i believe there are 12 screws in all. carefully remove the back panel of the tv. then using the allen wrench unscrew all of the screws that hold the boards and electrical components to the front panel of the tv. remove all components from the tv. (they should all come out as one entity) now take all of the components and place on the plastic mat you have previously placed on the floor. take the rubber mallet and beat the **** out of the components and the board. once it is in snickers fun size pieces replace back onto the front panel. then carefully (without damaging any parts) put the back panel of the tv on and put the 12 screws back in place. carefully wrap the entire television in bubble wrap and personally take back to the store and order the store supervisor to refund your purchase. he will inspect the tv and showing what a horrible job that the mexicans did at the assembly facility, he will gladly give you another LG 42" and an HDMI cable for your troubles...
no, honestly go to the options menu on the tv, check o make sure its not on a sleep timer or stand by mode, if the tv has been dropped, either by you our the store in which you purchased it, it could have moved a small coil that tells the tv to turn off (makes the tv think its over-heating once it reaches a small temperature) or simply call the manufacturer and ask wtf is up.
Posted on Dec 22, 2010
dcramer531
  • 1654 Answers
SOURCE: LG 42" tv LCD pannels inside tv have a cracked
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
Posted on Jan 18, 2011
My LG 42LV4400 has a red light in the bottom left corner but it will not turn on.
hello!
2 month and already quit? OK: first thing to do is to unplug TV off the power strip or wall outlet. Wait for a few minutes and plug the set back into the power source. Try to turn on the set manually, by touching sensors or buttons on control panel. some TVs have push buttons, some touch sensors. If your TV was set to "auto power on" mode, then don't touch anything after plugging set in. That's the only action you can do to "revive" the set. If you will be able to turn set on manually and "free standing" without any external connections, except power cord, check your remote control unit. 95% of consumers turn on their sets via "clickers". In case of complete failure, you might have month or 10 month left of factory warranty, depend on price you paid. Use it a.s.a.p! If needed. There is no magic button to heal broken circuitry.
Good luck,
Alex.
Feb 19, 2012 | LG 42LC2D 42 in. LCD HDTV
OUR 11 MONTH OLD 42" LG PLASMA WONT TURN ON THIS MORNING. IT'S AS IF THERE IS NO POWER GETTING TO IT .. TRIED DIFFERENT POWER OUTLETS BUT NOTHING .. IT'S A FACTORY 2ND AND HAS 12 MONTH WARRANTY SO TAKING...
All the best.
Oct 11, 2010 | LG 42PG20 42 in. Plasma HDTV
Red/green light keeps blinking.
This issue is related to a bad/failed power supply inside your TV.
Call LG to see if your TV is still in warranty. 800-243-0000
If not in warranty, the power supply is about $225.
Good luck. I do hope that I have helped you.
Jun 27, 2010 | LG 42LC2D 42 in. LCD HDTV
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
LG 42'' PLASMA HD TV, NO PICTURE BUT SOUND WORKS
change the red wite and yallow wires around it shoud fix the problin
Jul 31, 2009 | LG 42LC2D 42 in. LCD HDTV
1/2 picture on my vizio 42" TV
Are you under warranty? Chances are real good that you need the signal board....the one with the rca jacks and rf connectors. This may be pricey $$$$$ but will surely repair the problem.
Power will not stay on
With a problem like this, I would use the warranty for the TV.
It's possible a circuit board failure has occurred and the TV is automatically turning itself off to protect it from further damage. Is normally called " Protection Mode " for most TVs.
Being that it's 2 months old, it should be under warranty regardless. I would recommend contacting the store of where it was purchased and have them help you with the warranty issue.
May 04, 2009 | LG 42PC1DA 42 in. Plasma HDTV
No picture or sound on LG 42" Plasma
Hi Craig,
Your Tv has a 1 year warranty, you should contact Customer Service as soon as possible. This is the number in the USA 1-800-243-0000
If needed this is the Global Site. www.lge.com/products/category/list/tv.jhtml
Enter your country then click on Support for the Service Number.
If this helps please rate this solution as a FixYa.
Lone99star
Jan 29, 2009 | LG 42LC2D 42 in. LCD HDTV
LG TV completely dead
I'll think your power supply is down.
Since your tv is 15 month old, you've still got waranty left.
Just contact you supplier or LG service.
Kind regards,
Gerard
Jan 25, 2009 | LG 42LG50 42 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
291 people viewed this question
Computer Repairing
Computer Repairing
