Question about RCA Televison & Video
The picture on the screen has reduced to a half inch line across the screen.
  • 647 Answers
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical. Be sure to vote/rate me if this helped Thanks
Posted on Oct 05, 2009
Why has my sanyo flat screen television only got coloured horizontal lines across the screen?
That might be an issue with the TVs picture tube if it was not one of the LED or LCD TVs. Please get a technician changed it. If it was any one of the LCD or LED TVs, then it would be more expensive than you expect.
Jul 20, 2014 | Sanyo Televison & Video
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
Red line across top half of screen
Uh-Oh.. Sounds like the BGA RAM in the video circuit. (These units are Intel based and Core 2 duo if posted correct).. We can repair if you need help and its under warranty and sorry its not a home remedy situation..
ikenfixit.com
Jan 17, 2008 | Apple MacBook Pro Laptop Computer with...
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Aug 30, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Blue tint and lines on screen.
Those lines sound like "retrace lines" and several things can cause them. The most common are shorts inside the picture tube and shorted semiconductors in the video driver circuits. They can also be seen if the blue screen voltage is too high or if someone has tampered with the screen voltage control.
Jan 20, 2007 | Philips 28PW9536 28" TV
Televison & Video Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
