Question about Mitsubishi WD-62525 62" Rear Projection HDTV
REMOTE AND FRONT TV CONTROLS WILL NOT WORK. HAVE
REMOTE AND FRONT TV CONTROLS WILL NOT WORK. HAVE TO MANUALLY TURN ON AND THAT IS THE ONLY BUTTON THAT WORKS ON THE FRONT
  • 192 Answers
SOURCE: no control from the remote control
On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it.
Posted on Sep 02, 2007
  • 192 Answers
SOURCE: Mitsubishi WS65411. Front panel dead.
 This set has a keyboard lock feature and it can be removed by pushing in the menu button on the front keyboard on the set for about10 seconds. This should take care of your problem.
 Reply to this post if you have any questions and I will respond.
Posted on Oct 14, 2007
  • 31 Answers
SOURCE: Mitsubishi DLP WD-52525
your formatter board is bad. it can be repaired (sometimes) but they mostly just replace the part. hope that helps. need anything just ask
Posted on Apr 23, 2008
Slinteriors
  • 8617 Answers
SOURCE: green power light will not stop flashing and tv will not turn on or off
You need to replace the 1000uf capacitors on the DM board thats the classic symptom of the DM caps being bad the light continues to blink repeatedly. If you need more info on the repair let me know.
Posted on May 16, 2008
SOURCE: My TV has stopped responding to the remote control (and the universal remote) and the front panel buttons don't work
waynejman, I have the same exact problem, can you tell me what your outcome was?
Posted on Nov 16, 2008
Have zenith tv with zenith remote working fine. Wrong buttons were pushed trying turn off tv in the dark. Now remote doesn't work. Good batteries. H24F36DT. Ztv. And Zenith tv remote! Non universal..!
I don't have one of these, so a couple of guesses: turn on TV from front panel and attempt to turn off from remote. If that doesn't work turn on TV from front panel and look for setup menus which may have gotten trashed somehow. Take batteries out of remote and leave out for an hour. to see if it resets itself. Have you called Zenith help line?
Service manual: http://www.go-gddq.com/upload/2009_08/09082716157372.pdf
Feb 08, 2015 | Zenith Televison & Video
RCA Truflat TV 27F522T is completely locked both manually and remote do not work. Was working manually but after checking menu for block accidently FPA locked not can't turn on tv at all.
You must have its remote control to unlock this TV. Try to make your remote control get repaired, and check these.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 28, 2012 | Televison & Video
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I accidently locked my citizen tv and I can't access any buttons
Front Panel Lock
This feature allows you to lock the buttons on the front of the TV. Even when the front panel lock
feature is ON, the TV operates with the remote control.
• To lock the buttons on the front of the TV, make sure the TV is turned ON, then press and
hold the ON•OFF button on the remote for approximately 5 seconds.
• To turn off the front panel lock, make sure the TV is OFF, then press and hold the
ON•OFF button on the remote for approximately 5 seconds. Now the buttons will operate
properly.
http://support.ttetech.com/RCATV/Assets/pdfs/E13320_1558177E_IB_e-02.pdf A manual for a similar model if you need it. Many of the controls should work the same. Good luck and please leave feedback!
Oct 10, 2010 | RCA E13309 13-Inch Diagonal XL-100¿...
Antsig AP593 universal remote
Not sure if you've decided to throw your remote control away already or not. But try using the manual search code. Basically press "TV" (light blinks once), then press the "Up" channel button and the "up" volume button at the same time (light comes on permanently), then hold down "Power" whilst putting the remote RIGHT IN FRONT of the place where your tv receives signal (usually where you can see a light), and I mean right in front! Hold it down until your tv powers off. Then it should be configured and working. It took me about 1 minute or more for the TV to react and turn off. Then you can check if it turns on again and if the channels are working.
Jul 17, 2010 | Televison & Video
Tv doesnt respond to buttons or remote
this is looking like a common LG problem our tv started doing this tonight
May 15, 2010 | LG 42LC2D 42 in. LCD HDTV
Can't program emerson tv control volume or to turn it off.used all codes.not working.all other controls work. Thanks,ladybrd
If this is a new Emerson flat panel lcd tv from Walmart, there is a chance that the remote just wont work. I've had problems with these Emerson's often with all dish network remotes. you can try doing a search on the remote itself though. Turn your tv on manually, then push the tv button on the remote and hold it until it flashes, then hit the tv power button on the remote, then push the up arrow button continuously (not to fast though) until the tv turns off and then push the # button (below the 9 button) and the remote should work. There are some new tvs' that these remotes just wont program. I hope yours works.
Jul 22, 2009 | DISH Network IR Remote Control
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Tv turns on manually, but auto flips through channels and you can't use remote
Found this in another forum (www.hometheaterspot.com) and it fixed my remote problem:
"...it's possible that one of the front panel buttons is "stuck" or shorted, and this could cause the TV to ignore commands from the front panel or remote. But this should also cause the Power command to be ignored, too. You might try pulling off the front panel and disconnecting the front panel buttons and then see if the remote works."
Oct 19, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
15 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
