Question about Samsung Audio Players & Recorders
I dont find screws .a pair of samsung loudspeakers from a mini component .each loudspeaker has an eigth inches speaker .I need to open it for replacement but I dont see any screw. the face is made of vinyl a 180 space surrouind system.please help .JIMMY from South america Machu pichu
  • 647 Answers
Along the rim (outside circumference) of the 8" Wooffer there is probably padded material that covers up the screws check under there.
(did I make you say underwear?)
Posted on Oct 05, 2009
How can I connect it to get the most power out of it?
What load is the amplifier designed to drive? It will only deliver maximum power into the optimum load. The loudspeakers are probably 4 Ohms, but the amplifier may well be able to drive 2 Ohms per channel. This means that you need to fit two more loudspeakers This is probably not possible. Alternatively, if the amplifier can be bridged AND can safely drive 2 Ohms bridged or 1 Ohm per channel, you should connect the two loudspeakers together (+ to + and - to -) and connect them to the amplifier output terminals indicated for bridge (often Left + and Right + but sometimes Left + and Right -). If the amplifier can't drive 2 Ohms bridged, do not connect the loudspeakers together, buy another amplifier and connect one loudspeaker to each, with both amps in bridge mode.
Remember that loudspeaker and amplifier power ratings are always massively inflated in the manufacturers' data, often by a factor of 4 and sometimes by 10 or more. You speakers may not be able to cope with a whole amplifier each, so proceed with caution.
Jun 07, 2015 | Pyle 2 Channel 4000 Watt High Power MOSFET...
SAMSUNG N110 mini laptop. Can't get any sound from my laptop unless i connect headphones. Any Solution? Pls Help.
If the headphone socket is rarely used, the contacts can tarnish switching the loudspeakers off. Check your speaker icon first before blaming the socket itself.
Jun 06, 2014 | Computers & Internet
How do you remove the passenger side rear door panel in a 2006 Fiat Punto
1 Prise out the trim cap and undo the screw securing the exterior mirror inner trim panel of door
2 Where a manually-adjustable exterior mirror is fitted, prise the rubber cover off the adjustment lever, then unscrew and remove the locking collar using pointed-nose pliers.
3 Pull the panel from its location to disengage the retaining clips. Disconnect the loudspeaker wiring connector and remove the panel.
4 Lift off the trim caps, undo the retaining screws, then remove the door interior handle surround.
5 Carefully prise off the loudspeaker grille then undo the three loudspeaker retaining screws. Withdraw the speaker from the door and disconnect the wiring connectors.
6 Undo the three retaining screws in the loudspeaker aperture, and the single screw in the oddments pocket just below the aperture.
7 Lift out the loudspeaker protective cover and withdraw the loudspeaker wiring from the base of the cover.
8 Prise out the trim cap and undo the screw securing the rear of the trim panel to the door frame of Fiat Punto car.
9 Undo the screw at the upper front corner of the panel, and the remaining four screws securing the lower edge of the panel to the door frame.
10 Using a suitable forked tool inserted between the door and the trim panel of Fiat Punto, release the press-stud clips located around the edge of the panel, then lift the trim panel upward.
11 Pull the panel from the door, noting that the lower window aperture weatherstrip is integral with the trim panel and must be released from tie door as the panel is withdrawn.
12 If work is to be carried out on the door internal components, it will be necessary to remove the plastic sealing sheet from the inside of the door. Start at one comer of the sheet and carefully peel it away, using a sharp blade to split the sealant bead, if necessary.
13 Store the detached sealing sheet such that it cannot become contaminated with dust; this will allow it to be re-used later.
Source (with illustrations) - Door inner trim panel removal and refitting FIAT Punto
Feb 22, 2013 | Fiat Grande Cars & Trucks
Hello how does the loudspeaker work ? thanks
Hello.
During a call, select Speaker ? Yes to activate the loudspeaker.
Please rate.
Aug 01, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
Q: no high frequenties are heared,tweeter/filter problem ? how to open the box to replace components ? it is a Mission M73 loudspeaker
To open the speaker, remove the rubber 'grips' from the holes that hold the protection screen. Screws are behind them...
Jul 16, 2011 | Mission M73 Main / Stereo Speaker
Loudspeakers don't work
Hi,when a phones loudspeaker doesn't work, it means that the speaker of the phone that makes you hear the ringing tone and talk with speaker on is bad and will need to be replaced.
When you replace the speaker the speaker will work.
Have a nice day.
Sep 12, 2010 | HTC HD2 Smartphone
Radio works well in headset mode but has a lot of disturances in loudspeaker mode
Hi Friend,
When u are hearing the Radio or Music Player in your mobile by using the headset its clear but when u are using thro' loudspeaker its not clear because of below reason,
1.There may be problem in the Speaker(LoudSpeaker).The Solution is u may change your speaker by giving to the Service Center.
Regards,
Ayyasam
May 31, 2009 | Nokia 7610
Loudspeaker Repair or Buy New Replacement?
I have tried the repair thing before. They can be repaired the only problem is they dont seem to hold up as good or for long. I found it better just to replace speekers with new ones
Oct 23, 2008 | Cerwin Vega LS-15 Speaker
Loud speaker during call
When the call will be in progress u have to see on the right handside corner of the screen of ur handset, option of "loudspeaker" will be there OR u go to "options" on the left handside of corner of screen.Press it and loudspeaker will get activated.
Oct 20, 2007 | LG KG800 Cellular Phone
62 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
