Question about Sony KP-53HS20 TV
The picture is blurred (double vision) and the picture is also bowed. It appears the bulbs are out of focus. Is this fixable?
  • 647 Answers
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Posted on Oct 05, 2009
Magic focus is not clearing my problem ..what can be done ?
disconnect and reconnect to reset...then double check all settings and wiring...also, clean for any dust particles
Feb 05, 2012 | Hitachi 43F300 43" Rear Projection...
How do I get the double vision out of my tv
double vision? is this multicolored. red green blue? is the picture bowed. Have you tried going to setup in customer menu and adjusting convergence, Both manual and autoconvergence.
Oct 22, 2010 | RCA HD52W56 52" Rear Projection HDTV
Blurred camera vision
Make sure the webcam is clean
Some cameras have a focus ring around the lens. This has to be rotated to bring the picture into focus.
Others rely solely on the software.
If you have to re-install
Unplug webcam
Uninstall old webcam software
Restart computer
Visit the webcam manufacturer's support website and download new software
Oct 16, 2009 | Speed Link Computers & Internet
Borders bowed inward,blurred red,blue, & green
the next time it is not working go into the customer menu with remote and call up the convergence grid and look---there---if convergence is way off and or comes and goes---this set uses 2 Stk-392-570 ic's and it is quite common to see them become intermittant.
Aug 03, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Picture is distorted, double vision, looks like 3d.lines are arched or curve. colors don't line up. screen is bowed or warped. its a sony kp- 57ws600, 57 in. rear projection television. can you help me...
Try going into the video section of your menu, and pressing RESET on your remote control. If this doesn't fix it, try your quick start guide for setting the convergence and focus.
May 17, 2009 | Sony KP-57WV600 57" Rear Projection...
Double Vision & Bowed Screen
Chances are that the convergence amps are bad.
If those are mounted on a separate board, replacing the board would be the easiest thing to do. Running the magic focus or touching up the convergence in the customer menu may be required.
May 04, 2009 | Samsung HCN653W 65" Rear Projection...
Double words and blurred picture,
Is the picture bowed in too. first consult "the fl231 problem" article under the tip and tricks section under my profile. THis MAY be the problem. Otherwise you have a convergence issue. convergence is controled by three cuicit boards in this set. Setting the convergence on this set is tricky. try autoconvergence see how far it gets. let me know and i help you trouble shoot further
Nov 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double focused, red and green, bow in picture top and bottom
hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Jul 08, 2008 | Hitachi 65S700 65" Rear Projection HDTV
Blurred colors and bowing top and bottom
the problem is the convergance and would need to have the amps replaced. may be some resistors as well. the repair may cost $350.00 or so. there is no bulb inside just three CRTs which are no longer available for your set.
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Sony KP-53HS20 TV Logo
244 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
