Question about Ovens
I have a custom line hotpoint ele. wall over and need to replace the gasket around the oven that meets the door...also need to replace the gasket around the window on the inside of the door. the serial # is 0029148. I assume this oven was installed when the house was built in 1960
Master_Tech
  • 770 Answers
SOURCE: Thermador built-in double ovens p/n SCD 302 TP
post your email i will send u the manual
Posted on Jan 26, 2008
  • 184 Answers
SOURCE: Wall Oven does not fit flush into built in cabinet
I HAVE SEEN SOME CABINET MAKERS BUILD A TRIM PIECE THAT GOES ALL THE WAY AROUND THE EXISTING HOLE THAT HAS AN OUTSIDE DIMENSION LARGER THAN THE CABINET HOLE AND AN INSIDE DIMENSION TO FIT THE REQUIREMENTS OF THE OVEN. IT ATTACHES TO THE FACE OF THE CABINET AND STAINED TO MATCH THE CABINET FINISH.
Posted on Apr 10, 2008
  • 44 Answers
SOURCE: How to clean the inside of the glass door of Electrolux Wall Oven
Hi
open door and along top you will see 2 screws undo but hold door at same time then just lift out and clean.
hope this helps
Posted on Mar 21, 2009
barkencoa
  • 3463 Answers
SOURCE: the outer glass on my hotpoint oven door has
You must replace it with the glass as supplied by the manufacturer, as it is is special heat tempered glass.
Posted on Nov 11, 2010
  • 14 Answers
SOURCE: after the electricity went off to the house for a
First, you need to check the 2 circuit breakers. One goes to the control board and the other one goes to the heating elements. If the heating elements still do not work, you would need to check them for continuity.
http://www.appliancepartspros.com/ http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/
Posted on Feb 14, 2011
How do I replace the jenn air wall oven seal?
Oven Door Gasket - How To Replace - YouTube
? 4:25
www.youtube.com/watch?v=S9FxENXfIYo
Aug 29, 2012 - Uploaded by AppliancePartsPros Buy the new Oven Door Gaskethttp://www.appliancepartspros.com/range-cooktop-oven-gasket-seal ...
Sep 12, 2015 | Ovens
How can I clean an oven door gasket that need to be cleaned?
I think you can replace the gasket but most manuals says to NEVER clean the gasket EVER
Feb 12, 2015 | GE 27" Built-In Double Electric Convection...
Trying to find piece of heat resistant fabric (don't know name - something like old asbestos) to replace degenerating fabric on light fixture gasket on otherwise perfectly working caloric electric wall...
If it would help you to find the model number, I would look for a way to remove the oven door. Usually there will be a release near the hinge bracket that you push in or push to the side to allow the bracket to release and you can remove the door to see the ID plate. Otherwise, I would suggest going to a wood stove dealer and looking at the door gasket material they have in stock. They usually have rolls of heat resistant gaskets for sealing doors and glass panels in wood stoves. Last idea would be exhaust gasket material available at Napa Auto parts. Good luck!!
Nov 04, 2013 | Ovens
The outer glass on my hotpoint oven door has shattered do i need special replacement glass
Nov 11, 2010 | Hotpoint DY46 Style Line Stainless Steel...
Door will not close all the way...
This is likely one of two problems. Either the fiber gasket is getting in the way or if it is like ours one of the hinges is broken or bent. The Hinges can be replaced for about $13 a piece and is not a difficut job. On our the oven was also opening more then 90 degrees and wouldn't close more then to about 1.5 inches away from full closure.
Jan 09, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
(1)Cannot find location of model number. (2)Cannot locate service manual. (3)Need to clean oven. I believe the ovens (double/wall/electric) were installed in, or around, 2003, 2004. Simple want to know the...
need to know what model and brand you have.
most newer ovens only need you to remove the racks, then push the button for self clean, push the button to allow about a 3 hour clean cycle and it should then go into a lock the door mode. after the time is up it will need to cool down and then you should be able to open the latch and wipe out any burnt residues.
Dec 31, 2009 | Ovens
Hotpoint self-cleaning oven will not release door latch and open.
no you will have to replace the catch if its more than 20 years old maybe you should think about buying a new oven
Sep 27, 2009 | Hotpoint DY46 Style Line Stainless Steel...
OVEN DOOR GLASS BROKE
I have checked rhe Hotpoint website for your model oven and cannot find it listed.
So I can only assume that you are not in the u/k. you will have to check with your Hotpoint service agent wherever you are, but normally they are available as a spare part..
Sorry I can't help you further.
Jan 03, 2009 | Hotpoint SY21 Style Line Gas Single Oven
Ovens Logo
96 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
